pmexpert
Hey guys,
Decided to share my experience with piston slap I had. 6.2l 2008 Cadillac escalade with 40k on it.
Piston has been broken three times, three times the same cylinder. three times was replaced by the dealer free of charge, but they didn't solved the problem. So I decided to work with that by my own. Found good workshop I can trust and disassembled the engine. The reason for the "piston slap" was the thermal clearance between piston and sleeve. It was too big in one cylinder and that caused piston had space to play inside the cylinder to broke an upper part of it.
Here is the photo of my broken piston.
This is not good clearance
http://www.youtube.com/watch?v=27Pvcy4cl0s
The reason for that is thin pistons GM use for many engines. Theirs size is too sensitive to the temperature. When they are cold, clearance is bigger, so pistons are making slaping noise. As soon as engine achieves normal tempreture, the clearance become normal, so no or realy quite sounds can be heard.
So after seeing all this decided to make an upgrade.
I've decided to make it supercharged
First of all I studied stock sleeves. They were looking terrible. Thin, with different wall thickness from side to side. So everything should start with the new Darton sleeves set.
So for the time being have lot of engine parts to start:
1. Darton sleeves
2. 416ci balanced stroker
Lunati crankshaft
Lunati H-beam rods
Wiseco pistons -15cc
Clevite bearings
3. Ferrea valves(stock size)
4. Lunati dual springs with titanium locks
5. CompCams push rods
6. CompCams rockers trunion kit
7. GM Performance lifters
8. GM Performance gaskets
9. ARP head studs kit
10. ATI damper
11. Trick Flow timing chain and gear set
12. CompCams camshaft 115 lsa
13. Dynamics fuel injectors 1000cc
14. 2*50mm blow off valves by TIAL
15. Vi-pec v88 engine controller
16. MAP, temp sensor
17. Walbro Fuel pumps 255lph and 400lph
18. Two superchargers Vortech V2 SQ Sci trim 17psi each
19. Fuel and air piping etc etc
So waiting for the stroker only to arrive in the end of next week, to start the process.
Now looking for parts for the gearbox and transfer case. Already ordered driveshaft.
But actually know nothing about stock rear axle.
How strong it is? Maybe somebody knows that?
1. Darton sleeves
Lunati crankshaft
Lunati H-beam rods
Clevite bearings
10. ATI damper
