Engine setting for years, what's the best way to prepare for start up?
HDRock1
HDRock1
Flint,Mi
Ok, got the Gaskets, bolts,T stat & new coolant,
so the O rings in the Fel-Pro MS98000T Manifold Gasket Set, are for the fuel lines, correct ??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Something like that two small for the lines into spider. Slightly bigger on for a solenoid on upper section. Oval for spider and flat paper one for dizzy.
Redhoe01
The BDG
Forney, TX
What a good thread. I am about to go through the same exact thing. A 95 suburban sitting for 5 years. Rock, how easy was it for you to drop the tank, I have never messed with anything but a fuel filter before when it comes to fuel sytems.
HDRock1
HDRock1
Flint,Mi
No to bad really , had to cut hose clamps for filler and vent, cuz the way they were installed, no way to get a socket wrench , or anything on ,positioned new ones right ,no problem.
Be sure to put penetrating oil on strap bolts
And getting lines off fuel pump, see thread---, The tool I used is ,Tool I bought in pic
http://www.tahoeyukonforum.com/forum/showthread.php?t=42559
Another thread , http://www.tahoeyukonforum.com/forum/showthread.php?t=42538
Took all day to clean the tank out
D Rollins
