OHSIXX
Milwaukee
Cleaned up and secured all the wiring for my retro, adjusted them, and went for a short spin to grab a few pics. May have to adjust them a smidge lower.
The first 2 pics are from inside the truck(driver's view) and the other two are just angled outside shots.
Pachanga02
Ny
They look great I was thinking about doing that to mine. Jason about how long did each light take?
Rivieraracing
Looks great Jason, how much (if you don't mind me asking) was the retro and what projectors did they put in for you? From the looks of the first road pic, I'd say your projectors are adjusted perfect up and down!!
BlueTahoe2001
Charlotte, NC
Finished the knock sensors up this morning. Truck runs great and doesn't have any more codes! Gotta order some LT headers next and a AeroForce Interceptor gauge.
OHSIXX
Milwaukee
Thanks Chris. Most of the info is in this thread if you didn't see it before:
http://www.tahoeyukonforum.com/forum/showthread.php?t=42389
Just under $700 with new headlights included shipped to my door. If you could spare the downtime and just send him yours-you would save alot ;)
The light output is amazing-so crisp and focused. Thanks for your opinion-I think they are close(wasn't flashed at all while out checking them). It is hard to take night pics with a cheaper camera too. The lights don't throw as much glare as the pic shows. PM me if you have any other questions.
-J
rob3827
philadelphia, pa
I changed my fuel filter, PCV valve, adjusted the exhaust(exhaust was hitting the rear axle housing), gave her a well deserved bath
That retro is very cool, Jason!!!!!! I like :)
DuckHunter
Senior Member
Arkansas
Replaced my fuel pump/filter and lines, cv axles, Finally smoked the 3rd break light and corners on the headlights. Washed and waxed it, ordered a new 06 sierra grille and billet insert. Believe i have run out of things to do to it. Shes still runing strong little less than 220000 deabting on selling it just hard to part with it
OHSIXX
Milwaukee
Damn that was alot of sh*t to do....Well done and looks really good. There is always 'something' to do/mod :D
____________________________________________________
Thanks Jacob....
Rivieraracing
-J
No wonder I hadn't seen a thread about it, it was in the vendors section!! lol
Thanks for the info Jason, someday I'll do the retro thing to my headlights!!
Bikeboy80
Pa
Got about 90% of the sound system hooked up and tested before I started to put some panels back. I also did the antenna delete mod, ran a wire up the door weather strip and put in the plate w/o hole.
JochenWoern
Sacramento, CA
She certainly still looks GREAT. If she is still running great, WHY sell her?
brudgers90
color matched the grill today and ordered some h1 hids to go in the kc
---------- Post added at 08:18 PM ---------- Previous post was at 08:16 PM ----------
can i order those moldings for my truck the chrome ones on yours?
BigBlackTrain
Atlanta, GA
Lots of Stuff....
My Acura TL Type S has Red ambient interior lighting, so I decided to do the same. It doesn't replace the dome and reading lamp, but gives a slight Red glow to the cup holders and front floor boards. I have the lights connected to the power and ground of where the CD changer was connected, so it dims with the rest of the interior and they don't turn on until the lights do. I love it. I also installed my AVIC-220 Nav unit to my Pioneer Headunit. Installed Hella Black Magic Flood lights behind front grill, mounted to radiator supports and put H3 100W bulbs in instead of the stock 55W that comes with them. Removed the 6 disc denali in dash CD player and replaced with another compartment. Installed 4 Diamond Audio 6.5" speakers, 4 one inch Diamond Audio Tweeters, and crossovers. Washed and refilled fluids. She is riding dark. The first 2 photos are the front floor boards, but one is with a flash and one is without.
Yuko04
"SquareBODluvr"
MN
Well if you ever de-badge....hook me up with the ones behind your rear tires:Handshake:
JochenWoern
Sacramento, CA
The chrome mouldings are original, OEM Yukon trim. I therefore assume you can order these, YES.
dizhai
