engine cut off, wont restart
yukonaetahoe
Oakland, CA
Went to turn the truck on this morning. Everything went well, let it warm up like usual. Walked out to move the wife car. Walked back to my truck and boom it cut off. Never happened before.
I go in to turn it back on and its just cranking....but won't turn back on. I can smell the gas so I doubt its the fuel pump. It's probably not the starter because its turning over fast, the lights are still on so I doubt its the battery?
What could it be. This happen to my cousin on his sierra but because someone did a bad job when they changed out his fuse box. Some wires didn't make a good connection.
I've done nothing close to that.
Any trouble shooting I can try? I will do the alternator test tooday by removing the negative wire if I can jump start it.
kaoticlife
Port St Lucie, Florida
Check fuses inside and in the engine compartment
also maybe the crank position sensor if we have one? havent had that problem on my chevy but had 5 ford powerstrokes and that is the culprit most the time with those. do we have a crank position sensor (cps) or cam position sensor on these trucks?
HDRock1
Flint,Mi
Yes we do have a crank position sensor
First check for spark and fuel press, go from there
yukonaetahoe
yukonaetahoe
Oakland, CA
I checked the fuses and they are good. I pulled off a sparkplug wire and held it close while someone cranked the engine and no spark. Tried putting it infront of some metal for ground and also no spark.
Next step?
HDRock1
Flint,Mi
Next step?
Check for spark from coil
yukonaetahoe
yukonaetahoe
Oakland, CA
Coil to distributor or distributor to coil?
Do I need to remove the air filter and leave the TBI exposed while I crank the engine? Coil sits underneath so I'm not sure how else to get to it
Donnie Yukonie
Yates Caretaker
when was your last tune up the rotor might not be burnt up and not making a solid connection with the cap and a crank sensor wont stop the vehicle from running trust me i know had it unplugged after a tune up noticed the CEL on and drove all the way to autozone with it unplugged:fc5716bd:
yukonaetahoe
yukonaetahoe
Oakland, CA
I am about to change the rotor and cap. If that isn't the case, where do I check for coil spark? At the connection to the distributor cap or connection to top of coil
yukonaetahoe
yukonaetahoe
Oakland, CA
It wasnt the rotor or cap. I pulled the wire at the distributor to check for coil spark and nothing. Probably replacing coil next.
yukonaetahoe
yukonaetahoe
Oakland, CA
Got the control module tested and it passed. Damit. Getting the coil tested now..... Don't know what else to do
Drewphil
