Tach Help
tbert321
Connecticut
Im looking for some insite as to what might be wrong with my tachometer. I know its not really that big of a deal but since the gauge is on my cluster i would like it to work. Ever since i bought my 97 Hoe a few years ago my tachometer has never worked. I have replaced the ecm/computer (whatever you want to call it) with no luck, and i recently replaced my gauge cluster (with a 99 escalade cluster which looks awesome) and still had no luck. Just wonder if anyone else has any ideas as to what the problem might be or atleast where i can start looking. Thanks.
Kman965
Did you figure this out
I have a similar issue with my 97 Tahoe. Tach, odometer, speeddometer and prndl12 quit working. Cluster is not problem, replaced with working one and same items didn't work
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Check for any damages whit wires on you ignition coil connector.
---------- Post added at 04:41 PM ---------- Previous post was at 04:41 PM ----------
if tach, speedo and ind indicator not working you have burned out your transmission fuse circuit and technically your tranny should be in a limp mode right not. if not in limp mode then you only need to fix one wire likely.
JeffK
