no sound with xm
bsims3996
alabama
i just installed a pioneer avh-p6000dvd head unit and a pioneer gex-p920xm xm unit. everything works fine except with xm on there is no sound. the display shows what song is playing but no sound. the tuner, cd, and dvd all work fine with sound . its only the xm. any ideas what could be wrong??
Anthony
2004 Tahoe LT (MA)
Westen MA
Try turning the volume up......
But seriously, Did you use the Stock XM antenna or aftermarket?
What do you have? Tahoe, Yukon, Escalade, and what year? Premium sound?
Does it show you XM data and channel names?
NathanJax
Vacation Nathan
Jax, Fl
Is your IP Bus cable on the INPUT and not the OUTPUT ? I know it sounds funny, but usually(95%), that's the case. That's why your getting data but no audio.
JKmotorsports
Austin, TX
^^^What Nathan said. The IP Bus cable needs to be plugged into the black plug on the 920. If it's in the wrong plug, you'll have power and a display, but no audio.
bsims3996
bsims3996
alabama
thanks nathanjax. even though i feel stupid as hell at least it works.
thanks again!!!
NathanJax
Vacation Nathan
Jax, Fl
thanks again!!!
The only reason I knew is because I do it ALL THE TIME... I was an installer for 6 years, and no kidding, I've done it probably 40 times. It's just one of the small things you overlook. Hopefully you didn't have to take the whole truck apart to swap it.... That's what usually happens to me...
:Handshake:
JamesinAbilene
