new to this forum need some opinions
johnnunez29
ive never worked on a truck much less anything with autoride. i just bought a denali and it has the autoride message. my rear struts or air bags are shot. im planning on dropping it but i just spent a ton of $ on changing the a/c compressor and replacing the broken dipstick(biggest pain in the arse! 300.00 just labor plus 70.00 for oil chnage and oilpan gasket) im trying to figure out what setup would work nice and not too much $$$$ thanks
Alex33
Check with NorcalSS. I believe he has a 2-3/4 kit that should work well with your truck.
NORCAL SS
SUV SUSPENSION GURU
to bad you didnt hit me up before you didnt need to do the autoride shocks.
What is your budget i can see if we can work something out.
NORCAL SS
SUV SUSPENSION GURU
ok all you do is diconnect battery and pull rtd fuse.
you can then do the belltech front/rear shocks
and the 2/3-4 kit
750 shipped
kensyl77
Arnott part #
The Arnott direct replacement part# is AR-2411. The price of a pair is $370 plus a $50 refundable core charge.
NORCAL SS
SUV SUSPENSION GURU
so you guys know if you read up they are not new units just use same valving parts and change bags
J
johnnunez29
where is this rtd fuse located??? sounds simple enough but i got no idea what fuse it is?
Max
Mile High
Denver
Under the hood in the fuse box on the driver's side, think it is 30 amp but it is listed in the diagram under the cover.
JeffK
