Console Safe by Lock'er Down
StevenFromTexas
Mr. Negative
Lubbock, TX
I purchased a Console Safe by Lock'er Down from Mobile Security Plus ( http://www.mobilesecurityplusstore.com/ ) for my 2010 Tahoe. The model number is LD2011A. The Console Safe does not block the USB port or 12-volt power port in the factory console, which is what kept me from buying a competitor's product previously. I added the Abloy High Security Lock option to the Console Safe.
The Console Safe was received on 06-20-12, and I installed it that same day. Being Mr. Negative, I'll get to the only minor complaint I would have, and it is one which I have read about a competitor's product: I wish the interior dimensions were just a little wider, but I can understand the reasoning behind the manufacturing process. O.K., with that out of the way, the product is fantastic and serves my main purpose, which is to be able to lock up a full-size 9mm pistol when I don't want the pistol with me when outside the vehicle. Plus, I can toss in other stuff like a checkbook, iPod touch, etc. to keep it safer from those pesky smash and grab thieves.
I may purchase a Chevrolet truck or a second Tahoe when the 2014 models come out, provided the 2014 Chevrolet trucks looks better than the current models or the 2014 Tahoe isn't sissified. If I do make a new vehicle addition at that time, and a Console Safe by Lock'er Down is available, that'll be the first modification I'll make to the new vehicle. I like the product. :)
My comments on the five pictures below:
Picture 1: Side view of the actual Console Safe with the two attachment screws in the plastic bag toward the upper left side of the picture, the two keys that came with the lock I ordered, the cover plate with the finger hole that covers the inside lower portion of the Console Safe and which can be used to keep some small items out of view inside the Console Safe, and the cutout portion of the Console Safe that allows access to the USB port or 12-volt power port in the factory console.
Picture 2: The cover plate that fits over the top of the Console Safe.
Picture 3: The Console Safe screwed down inside the factory console, and the underside of the cover plate that fits over the top of the Console Safe. There are four bolts on the underside of the cover plate that fit through openings on the top of the Console Safe. It isn't necessary to add a locknut to each bolt from inside the Console Safe if you wish to use the supplied sticky tape, but if you wish to use locknuts, do as I did and go to Home Depot or Lowe's and buy four 8-32 stainless steel nylon insert locknuts. (TIP: Attach the locknuts after you set the cover plate into position on top of the Console Safe when everything is outside of the factory console. You'll be glad you did. I wish I had done so before screwing down the Console Safe and then attaching the cover plate and locknuts. Things would have been much easier!) In my picture, you'll see one 8-32 stainless steel nylon insert locknut on the lower left underside bolt of the cover plate. I was just testing to be sure I had the right size locknut, and forgot to remove it before I took the picture.
Picture 4: Cover plate in posiiton, and you can see where the two included screws were used to secure the Console Safe to the floorboard. Prior to inserting the Console Safe, I had removed two screws that GM had used to help secure the factory console. Those holes were then used to secure the Console Safe.
Picture 5: The cover plate with the finger hole (which isn't visible in the picture due to the angle I was in trying to take a picture from above without falling into the second row :uhoh2: ) that covers the inside lower portion of the Console Safe where you can hide some small items if you wish.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
My comments on the two pictures below:
Picture 1: The felt cover is in place on the bottom of the Console Safe by Lock'er Down.
Picture 2: The finished installation, with the cover to the USB port on the left side exposed and ready for use if one wants to use it.
If you would like to get a 10% discount and order the Console Safe by Lock'er Down or some other product from Mobile Security Products ( http://www.mobilesecurityplusstore.com/ ), I have been advised you can enter coupon code Tahoe.
I'm a happy camper tonight. I'm positive about that! :)
plush
Still don't see the need for these. LOL, what is a checkbook, I have not carried (or used one of those in years. Also, why in the world do you carry an FS 9MM? I used to have a Beretta 92FS, just way to big to carry everywhere, get something smaller.
metalemt
Las Vegas
There's a hater in every console safe topic it seems :signs8:
I almost bought the other one but the whole needing new brakes stopped that. But soon enough, we'll be able to compare notes!
rankhornjp
Even if his gun were smaller, there are still places that are illegal to carry even if you have a license/permit. Better than being arrested or stuffing it under the seat for someone to steal.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
Tip: Don't leave your driver's license, insurance card, and concealed gun license with your handgun in the Console Safe. It might create a bad encounter with the law if you're asked to provide identification. :imo:
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
It didn't take long to make my first modification to this modification project.
The Console Safe will no longer be used for a full-size 9mm pistol storage compartment. I permanently removed the cover plate with the finger hole that covers the inside lower portion of the Console Safe where you can hide some small items if you wish, cut the felt cover in the right spot, and have used velcro fasterners to attach a holster that I won't be wearing anymore. Now, a .38 Colt Detective Special straight out of the 1960s is sitting in that holster. That leaves lots of available storage space for other items.
These Tahoes are fun to customize. And that Console Safe is a neat product! :)
edgaranah1
Corona California
Haha I might see a little problem there. I would def buy it but don't have a center console. ::(: lol
mikey42_69
Lets just hope you don't need it when your still in motion because its on your ignition keys.
Love the install and a great way to keep it safe from others.
I would love it if I can keep the center consul and they would come out with a glove box locker. Sucks that it will take the ONLY storage spot in the whole truck. JMO. Or a locker that is attached to the door and sits in the drivers door magazine pocket. that would also be great but very tight.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
If I wanted to, the key could be left in the lock so that with a quick turn, access could be obtained to the weapon. But then I'd have to remember to remove the key and put it in a pocket.
A picture below of where the weapon can also stay with very quick access when not locked in the Console Safe by Lock'er Down, and that's on the driver's side door in the black Allen rug:
snowjay
I'm a little late to the thread but I came across it during my search for a better locking storage solution for the Tahoe.
I like these type of vaults a lot, but I wish they didn't take up so much room in the center console. I use one of the console storage trays to keep small things like sunglasses, pens, napkins at the ready and then larger items below. It appears these vaults are too tall to still be able to still use that tray.
Right now I'm using a COM lock box (aka Gunvault nano) bolted to two of the console mounting holes. While it works for locking storage, the box isn't tall enough to store a holstered gun, it would be preferable if I'm required to disarm for my destination to just remove and store the gun and holster as a single unit.
alelex
Switzerland, GA soon
Thanks for your review of the console safe! I was looking for one, but I think with the 4 digits lock system (I know I'm bad with keys!).
RGNEWELL
New safe for Tahoe
Steven,
I am in the process of building a new design to compliment or replace the one you bought. I am not sure what people will want, but I sent one like you bought to the FBI in Cleveland for their SWAT Suburbans, and they felt it was too small. My new design will fill the console, and must be assembled inside. When it is ready, I will post photos. If you or anyone else, would prefer the new design over the old, I will swap even, customer pay shipping both ways.
Bobby
Lock'er Down® Security Products
:Good or Bad:
alelex
I'm not really sure wich one i will need to pick.
The USB port is available with the new design? And the power outlet? (I dont think but it's ok)
And with the future box (need to be assembled in the console) nobody will be able to "steal" the box right? (Sorry if my questions are stupid!)
Sent from my BlackBerry 9700 using Tapatalk
SuburbanPassion95
