need help... i have a 3" drop but its more like a 4" drop.
lynxnova
New Jersey
3" springs with spacers in, rides to low. It looks and feels like its 4" drop rather than 3"drop.... When I have. My kids in the truck the bumb stop hits when I hit a small bump. I need to raise it an 1" more, how can I do that? Can I add another spacer? Thruck stands like its even on the front and rear.... I don't understand Why is that, I installed the 2"-3"/4 " belltechkit from Tony, with. the spacers in and. It sits to low....
KMeloney
You haven't said what kind of truck this is on.
NORCAL SS
SUV SUSPENSION GURU
is the rear sitting lower than the front right now?
lx4life
I wonder if he has autoride , and do you have to do a free travel mod to prevent the bumpstop form hitting?
VTburban
Vermont
Mine sits exactly even too, which IMO makes it look lower in the back. Did you cut the bumpstops like Tony suggests? I haven't had any probs there, even with four adults and a fully loaded trunk this past weekend. You can buy different sized spacers on ebay...Sumo runs a 2" spacer and likes it.
quattrotman
Just throw some spacers in until you get the height you want.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
If this is the 739SP kit... I ran into the same "bumpstop always bottoming out issue" and the solution was to simply remove the bumpstops altogether. :Handshake:
L
lynxnova
New Jersey
I have a 2010. Chevy Tahoe non. Autoride.....I did not cut the bumbstops, and that's a good thing because if I did the rear would def. Be sitting lower than The. Front and I don't like that look......it looks great now but not practical when theres people. In the back....I would post pic later on today when I get home..... If I.could raise the rear 1" more would be good.....the springs are 5304 series from.belltech.....I have the spacers in the bottom part of the springs... Can I put a second set on top of the springs also?
yates ™
Resident Apple hater
Iowa
If you cut the bumpstops it would not make your truck any lower unless the bumpstops are the only thing holding the truck at that height in which case you are way lower then 4" anyways.
NORCAL SS
SUV SUSPENSION GURU
you can add spacers up top or get 2 inch spacers on ebay
VTburban
Vermont
Yup. The function of bumpstops is basically a last line of defense for the frame from the axle. Your springs control height, whic is why making them taller with spacers increases your ride height. I have the same setup on mine and cut the bumpstops like tony suggested, and have yet to bottom out. I might get bigger spacers too, for the same reason of extra load and to achieve a slight rake, but its really for looks. That's what it comes down to. If you don't like the way it sits, spacers are your best bet. If you're bottoming out with that kit, cut the bumpstops.
L
lynxnova
New Jersey
Thanks guys.....I do like the look now, but I don't like it when I have a load in The rear... The back drags lower with a load...... I like my truck to have a lil rake look to it...... This way when I have a load, it will look the way it sits now......... I will cut the bumbstops and add another 1" spacer, hopefully that will give me the slight rake look I'm looking for without the rear drag look when I have a full load...... Again I will post pic when I get home.....FYI...... I have pic and a video on my other thead ( just dropped the hoe) when I first installed the kit... If u guys like to see it....
---------- Post added at 12:06 PM ---------- Previous post was at 12:01 PM ----------
Hey guys, which way would u go... An.extra 1" spacer on top, or just remove spacer on bottom and replace it with a 2" spacer?
VTburban
Vermont
[/COLOR]Hey guys, which way would u go... An.extra 1" spacer on top, or just remove spacer on bottom and replace it with a 2" spacer?[/QUOTE]
I don't have experience there, bud, sorry. I know Sumo has a 2" spacer and likes it. Here's a link to the 2" spacers I'm thinking about:
http://www.ebay.com/itm/140623279770?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648
Good luck, let us know what you decide to do, and post up pics when you do it!
SRQYukon
Sarasota, FL
I have an '03 XL and had the same problem. I finally did the free travel mod on the rear and cut off the front stops and added short poly stops. That took care of it. These behemoths have a lot more suspension travel than you realize. Removing the factory stops gives you several inches B4 the stops make contact.
jackal78
