Question for you E-fan guys
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
you can always pull a tape measure on it...
another questions guys. can you get a different size belt and disconnect the clutch fan from the belt completely? seems like this would completely eliminate the drag on the belt
you'll be removing the clutch fan to install efans, but the pully won't amount to much undo stress to be worth going the entire route of pulling it and getting a shorter belt.
---------- Post added at 05:22 PM ---------- Previous post was at 05:21 PM ----------
This is something I would like to do aswell. Im new to the site and Im still gathering info. Im a big DIYer. I rebuilt the engine in my T/A so I think this would be a breeze. Just to get this straight, I want any 05+ dual e-fan set up the harness and pulley? Then I need to have a tuner turn the pins on? And possibly drop in a lower temp t-stat? Do I have is pretty much covered?
depending upon your radiator size for a stock look you may need the 34" radiator too.
JennaBear
Resident Ninja
San Diego, CA
No, that turns the water pump.
tybardy
everyone needs a Hoe
Gilbert Arizona
so the crank that turns the fan is also the h2o pump? thats interesting... no wonder i couldnt find that coolant leak at my water pump, i was looking in the wrong places
tybardy
Gilbert Arizona
hhahahahaha man my bill is gonna grow at an alarming rate!!! just dont get the rest of the forum in on this, i will be broke my monday
WoldD90
Off Road Addict
Atlanta, GA
I installed two 16" Procomp fans on my 04 Yukon XL with the 6.0. I bought them off some guy on the old forum. It came with a wiring kit that had a tap for the water jacket a relay and wiring for two fans. This kit was a POS. The fans pulled more amps then stated and I burned through the relay, the fuse and the wiring kit died.
I did not notice any appreciable benefit from the conversion, with the exception of the noise in hot weather from the fan clutch engaging when the AC is on, on a hot day.
I have a dual fan set up on my Land Rover and I was able to see a good increase in HP/Torque. But with our trucks having a good bit of HP from the factory, I did not see much of anything.
If you are going to do this, I would wire each fan up separately with it's own relay, fuse and wiring, this way if there is some sort of a problem, you will have at least one fan working.
I left my stock fan shroud on to keep the air focused as it flows through the radiator.
JennaBear
Resident Ninja
San Diego, CA
That is exactly why I refer folks to stick with the stock set up and allow the PCM to control the fans. The OEM fans work flawlessly and you don't have to rely on a switch or temp probe.
BOSS
The People's A D M I N
Dallas
Do the PCM controlled come on with the ac clutch? Can you adjust the temperature at which the fans turn on with PCM?
B
JennaBear
Resident Ninja
San Diego, CA
The PCM turns on the fans based off of temperature and/or AC pressure. The fans are also disabled above a certain speed.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
instead of tuning your current pcm, could you just swap out your current one for an 05+ one?
IIRC you'll create more issues going this route than to spend the money to hvae a BB tune. THe benefits of a BB tune greatly outweigh that of just getting a stock for stock swap pcm.
Pat
tybardy
Gilbert Arizona
Pat
X2
tune the pcm, there are so many benifits and you will NOT regret it!
T3rry
Calgary, Alberta, Canada
yeah, i understand the benefits, i just haven't done my research on it, and last i heard about people getting their tuned, they had to use premium fuel, decreased fuel mileage, etc...
also when i got one tuned for my 01 grand am, it cost me a lot of money, i had to buy one and put up a core for my current one, got the new one, shipped back my core, it got lost in the mail, i got screwed for the $100 or whatever, and then the tuned one wasn't working properly.
and i am in Canada, so shipping aint cheap :/
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
you can get a tune for 87, but the benefits of a BB 93 tune actually GAIN you MPG fuel economy and the extra cost for fuel outweighs the cost of the tune and fuel cost by the MPG increase! You can get an in person tune from BB for around $250.00! Hit up Jenna or Justin with BB for more insight!
Pat
JennaBear
Resident Ninja
San Diego, CA
No, you would need to have the PCM tuned for your vehicle (ie. VIN, year, make, model)
Who was your tuner? If they have free updates, you should hit them up for an update if you are unhappy with your current tune.
bass1775
Maryland
Okay, What's the best way to add these e-fans to my 98 hoe? I had a set of dual 15's (*Perma-cool) I had nothing but problems with the fans coming aloose from the motors. Had them repaired under warranty. happened again, took them out went back to stock setup. They came pre-wired, radiator probe adjustable temp setting and tapped into AC switch. Would like to try again but, may need more research. Any ideas? How about those flexalites?
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
you might want to try a new thread in the 91-99 hoe section.
Pat
TheFuzz
Idiot Police
Spurbury, VT
Pat
+1 on this. Since you have an OBS, you'll probably need to do a ground-up build. There are no PCM controlled options or OEM options for your year.
Flex-a-lite makes a very good product, that should be a good starting point. On your old kit, was it just that actual fans that were giving you problems? If thats all it was and you still have all of the wiring and stuff, you might be able to reuse alot of it, as long as it's in good shape.
johnsonwillie199
