Hopefully have a new O2 sensor on the way, thanks again Sun!! Also having a problem with my alarm on the denali going off when it's not suppose to, hoping all you alarm guru's can chime in and help me out!!
http://www.tahoeyukonforum.com/forum/showthread.php?p=476280#post476280
I had a similar alarm issue with my 99 Denali and it was completely random. It'd be sitting there for hours with alarm on and then at some random time it would give us two honks like the alarm was going off and then stop. No one was around it and it wasn't windy and the keys were on the counter so we know it wasn't the fob getting pressed in a pocket or something. Like it was just saying hello or something :lol: we never did figure out what the deal was with that.
Rivieraracing
Yeah, I wish it only did the 2 chirps like is someone bumps into it but not hard enough to set off the alarm, but it skips the chirps (well at least the 2 times I've actually heard it) and goes completely off for 6-7 seconds and then the siren stops!! All 4 times it's gone off, the windows have been up, no wind or nothing to set it off, and the fob in nobody's hands!! I'm going to take the fob apart and make sure there isn't a button sticking causing it to randomly go into panic mode!! Need to figure this out before the neighbors wanna lynch me!! lol
By the way, thanks for your input!
MeanGreen03
TX
Have you checked the voltage on your battery? Sounds like you battery is going out. Mine was doing the same thing for a while. For some reason when the voltage drops to a certain level it will trigger the alarm to go off. I didn't know it was the battery until it totally gave out and I had to replace it. That is when the alarm stopped its craziness.
Rivieraracing
I bought the battery about 5 months ago brand new, and it's the biggest Interstate battery I could get!! But it's still a great idea and will check it anyways here in a bit!
dznutts
Installed chrome inner door handles.:Wedgie:
The 'ER
Minnesnowta
I got dirty. A guy at work drove his little F-150 through a puddle and said it was really deep (he was in 4 wheel drive :chicken: ). So I HAD to go as well and it was a little puddle. The pics are before and after the deepest part but it maybe went up to the middle of my rims. I did get dirty though. :rocking:
DaRosa218
The Dude abides
Modesto, California
DaRosa, looks really clean!!!!! Couldn't stay away huh?!? Lol
No way man, I couldn't stay away any longer...The TahoeYukon Forum is like one big family to me! Just happy to be back in a Hoe :Handshake:
---------- Post added at 08:11 PM ---------- Previous post was at 07:58 PM ----------
Layed down some Mothers Stage 3 wax and smoked the tails. Still trying to put the interior back together. Someone broke in and stole the Pioneer flip up DVD deck when previous owner had it and most of the dash got smashed up. Looking to swap out the 94 dash for a 99 Eski setup.
So, before:
After, smoked tails:
And the wax job :)
Still need to take pics of the interior when its all cleaned up
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
Just got back to WA State today. I took her out and noticed a check oil level sign was flashing. I got some stop leak stuff. I am looking to possibly drain my transmission fluid this weekend. I gave her na quick clean up with the new Cal Car Cleaner brush. Thing works fairly well. I was surprised. Took lot of surface dust off.
electro
Kitchener, ON, CAN
I also changed my oil today. Cost me like 55$ with seafoam:/
That sounds okay I guess. What exactly does that sea-foam do? How did it work for you?
I emptied another can of Rust Check into the engine and headlight adjusting screws today.
Then adjusted the headlights.
I also took the mouldings of the passenger side doors of my 02 suburban.
Tomorrow drivers side.
---------- Post added at 11:30 AM ---------- Previous post was at 11:29 AM ----------
I think he means the fob battery. Is this the stock GM alarm you guys are talking about or aftermarket?
Alex33
I replaced a stone dead battery only to find out my fuel pump is no good too.
Diggerdan11
The State of Jefferson
Found out that the exhaust leak i was hearing was a broken bolt that attaches the exhaust manifold to the block. Yay! Ita going to be a pain the the butt to fix.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Those damn mailboxes are always trying to jump behind me too. I fixed mine by digging a new hole a few feet from my driveway, filling it with cement, and sticking the mailbox post in it. Once the cement dried I filled the hole the rest of the way with dirt and grew grass. That damn mailbox has never jumped behind my truck while I was backing out since.
Mailbox 0 : Me 1
CEN2MENTAL95
Banned
Expensive Long Island, NY
backed into my stoopid mailbox, got a nice lil scratch over my brake light. :emotions122:
Mailbox 0 : Me 1
easy solution: MAILBOX DELETE!
after all, the mailbox just provides the mailman a place to stick all my bills, and who the hell wants to get bills???
Rivieraracing
Drove the truck today to get a load of gravel, and during one of the stops I tried to start it back up only to hear a click and that was it!! Come to find out the positive cable at the battery was loose, and when I reconnected it and started it back up, my O2 sensor engine light went off and is still off!! Sooo hoping it never comes back on, that would be swell!! Also hoping that might be the reason for my alarm randomly going off without reason!! We shall see I guess!
---------- Post added at 07:58 PM ---------- Previous post was at 07:56 PM ----------
Yes I did replace the battery a couple weeks ago, but this has only been going on for 4 days now so don't think that is causing the problem!! And it's an aftermarket alarm, and in the 5 years I've owned the truck, this is the first it's given me problems!!
Pachanga02
Ny
Got it washed and cleaned the inside. Looks fresh for the next 2 days and then more rain.
ASG-MikeS
