best rotors and pads to buy
Gerdia
Perkasie,Pa
Sorry to hear you are having issues, but this is why it is better to order through a site vendor, I have the ability to help on issues.
That being said, I have never really heard of the R1's making any noises at all. What kind of squealing? Is it all the time? Just coming to a stop, etc. Explain a little further and maybe I can help narrow down the cause for you.
Just FYI, if you used a link I posted on the site then you were "Suppose" to be buying from me. SO, that being said, if you did that and have the email invoice they sent you I will take care of anything you need from them on this, for you. For your convenience.
Good day,
I am new to this site. I am looking for the brake kit you are suggesting but got a little confused on the web site. I have a 2005 GMC Yukon Denali XL AWD. Would you be kind enough to steer me to what I should purchase, this is normal driving, nothing extreme so I would like to stay in that 3-350 range. And I will purchase through your link, Thank you for you r time.
Gerry
Freedom Motorsports
I'll try to keep my situation updated.
Please keep us up to date. One sign to look for before AND after they check it out, go look in at what will be the back of the brake pad and see if you can tell there is brake quiet lube. If it looks completely dry, etc, then they didn't use any.
Also, if you can do so, or have someone help you do so, pull the driver side front wheel off and take a look at the metal clips at each end of the bracket holding the pads against the rotors, iif those clips show any signs of wear or discoloration then the shop didn't use new hardware.
Hope everything goes well, but if it doesn't, let me know anyway, even if it is in PM, I will get you taken care of.
Gerry
Welcome to the neighborhood!
Thanks for giving me the opportunity to help you. Below you will find all the information you need to look for. When you go to the site, enter the year make model information and scroll to find the products listed below.
Just go down the list and click the button to add each item to your shopping cart. Click each of those buttons only once, when you are adding them, you are adding them as an axle set that includes both sides. This package includes the rotors, pads and hardware needed to get the job done. If you install them yourself, go to the local parts store and purchase two to three cans of brake parts cleaner (yes, it takes a lot to be sure that you get everything good and clean before re-greasing everything), a pack of shop rags, and ask the guys at the counter for a couple of small one time use pad quiet grease and caliper to brake pad bracket grease and before installation. Clean the rotors, calipers and pad brackets as well as you can and allow to dry well. When re-installing, grease the caliper to pad bracket bolts and install the new rubber boots that come with the hardware. Then replace the old clips with the new clips. After placing the rotors in place, re-bolt the pad bracket in place and slide the pads down into them. Then re-install the caliper onto that bracket.
Title: GMC YUKON XL 1500 2005 Front Brake Pads - Posi Quiet Ceramic
Sku: 105.07850
Desc: Ceramic Formula & Scorched
$50.55 (axle set)
Title: GMC YUKON XL 1500 2005 Rear Brake Pads - Posi Quiet Ceramic
Sku: 105.08340
$46.02 (axle set)
Title: GMC YUKON XL 1500 2005 Front Brake Rotors - Cross-Drilled & Slotted
Sku: EDS.66040
Desc: Cross-Drilled & Slotted Brake Rotors
$112.01 (pair)
Title: GMC YUKON XL 1500 2005 Rear Brake Rotors - Cross-Drilled & Slotted
Sku: EDS.66045
$123.12 (pair)
Title: GMC YUKON XL 1500 2005 Front Disc Brake Hardware
Sku: 117.66010
Desc: Disc Brake Hardware
$16.05 (each)
Title: GMC YUKON XL 1500 2005 Rear Disc Brake Hardware
Sku: 117.66013
$12.00 (each)
Subtotal: $359.75
Promotional Code Savings: ck10
(ckelley affiliate 10%) -$35.98
Total: $323.77
Click the banner in my signature and use Promo Code= CK10 to Order
Thank you for your support!
Gerdia
Perkasie,Pa
Thank you, I will be placing my order soon.
Just ordered, thank you for saving me $300+
Eickybobby5050
