good budget speaker amp
the big blue bus
richmond, va
ive installed an alpine cde-123 headunit and i love it. ive replaced the front door speakers with some pioneer G1643R 6.5s and i have a set comming for the rear door too. im going to remove the ones from the roof all the way in the back since ill have subs eventually.
whats a good amp for those 4 speakers? would i just need a 4 channel 2-300 watt amp? whats the best speaker wire to get or can i just get some from like radio shack or somewhere. and i guess the best place to put the amp would be under the seat? i have chains and straps under the rear seats so id rather put it under one of the front seats.
awsomeaussies206
The size depends what the speakers put out, whats the rms combined and what's the peak combined... but a 4 channel is what you need.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
30 watts rms? A OEM amp from a stock Bose system could do that nicely. See if you can find locally. And for that little power you can use 18 ga wire from Radio Shack.
SunlitComet
OBS Jedi-Do Good
they go about 25-35 watts continuous. get me the year and model details of where the amp came from and I can email you the pinouts/schematics on how to hook it up.
bigblacktahoe
if ya got the alpine deck, check out the alpine ktp-445. plugs into the decks harness and puts out 45 watts rms, 90 watts peak. easy install.
the big blue bus
the big blue bus
richmond, va
i was reading that you pop the grill off and the speaker mounts to the door pannel itself but i cant find anypictures of replacing the rear speakers or removing the door pannels
AtomicHoe094
Atomichoe094
cleveland, OH
+1, your correct. Just push in the tabs of the grille and it will come off.. youll have 4 clips on the stock speaker....
Also crutchfield is having a sale for Alpine speakers.. buy one get one half off (one meaning a pair haha)
just bought some
the big blue bus
the big blue bus
richmond, va
poped the cover off last night lol. going to see if the speakers i got fit today. later on i may upgrade the speakers to higher quality but for now these are a lot better then stock just time for some subs in a few months
vsaravia
