comments on these Spark Plugs
WildBill
back when I was spark plug shopping, I read some on those. The only people that were saying anything special about them was bosch. To me, there is just more metal around the center electrode that would shroud the spark from igniting the fuel. One benefit, i believe, is multiple spark paths when one wears down. I would (and have) done stock ac delco plugs (rebranded ngk iridium) with ok results. I just cant see a benefit with the bosch 4. What were did you see as an improvement when you used them before, mileage, power?
ATL
the idea of those plugs is a good one but it just doesnt work out as well. when u divide your spark into 4 like that, the spark is significantky weaker. the plug is putting out the same voltage no matter how many times you spark it. so basically, you get 4 weak sparks instead of one good strong one
tony4143
i personally love the e3 plugs. i have used them in all my cars and in all my friends/families car. nothing but good things heard about them, better accel, and better fuel mileage.
Buzzcut
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Anything Bosch is junk IMO. AC delco will work the best. Alot of the plugs are just snake oil and I have yet to see any measurable gains on a dyno. YMMV
Yet, how many parts on your car were supplied by Bosch?
You want NGK TR5
They don't go by that number anymore. They go by four digit numbers now. What is their's?
abladeafficionado
You do realize that ACDelco plugs are rebranded? My stock plugs were NGK.
Bennie
Belle Plaine, MN
I have had nothing but good results with AC Delco, NGK and Denso. I have had bad results with Bosch and E3's. It could have just been the application but I had a 3-5mpg drop when I tried the E3 plugs in my '98 4 speed and '99 3 speed Chevy Prizms. I returned them to E3 for a full refund after about 1500 miles of data on each car. Wish they had been better. :(
pmexpert
Moscow, Russia
Have NGK iridium ix installed. Works fine. Don't think Bosch makes something really different, so you can try that ones easily. To see real different results you will need to change also coils and wires. Otherwise all sparks will work the same ;)
JeffK
