How to change the Fuel Filter
lamordnt
I am writing this short post to help anyone who is going to change their fuel filter. I just did mine tonight and could not find anything on here on how to actually do it. This is really easy to do and all you really need are two wrenches and something to catch the small amount of spilled fuel. Shouldn't take more than 30 mins.
This will be short and sweet so here it is. The fuel filter is located under the driver side door tucked on the inside of the frame. Find the fuel line and follow it to the filter. The filter is a silver tube looking thing with threads on both ends. One end, the end toward the engine, it has a rib on the end of it. There is also a black plastic looking support harness that holds the filter to the frame. DO NOT REMOVE THE BOLTS ON THIS. Leave it alone, the fuel filter will actually slide out of it so you do not need to try and remove it.
Here is where I had trouble. To remove the fuel filter you will need two wrenches. Put one on the fuel line nut and one on the filter and loosen the filter. Repeat on the other end. Be sure not to twist to hard and do not let the fuel lines twist at all. Fuel will start spilling out here so be sure you are ready to catch it.
Next, you will want to look at the end of the filter closest to the engine. You will see the fuel line here is actually pliable. Follow the fuel line until you see a little black clip. You can remove the fuel line from this clip and it will allow you to get the line out of the way of the filter so you can slide the filter out of its harness.
Thats it. Install your new filter and fire her up.
This should cut your time in half of what it took me to figure it all out. Best of luck!
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Before starting I recommend pulling the fuel pump relay/fuse and starting the engine. Let it run until it kills over on its own. This will decrease the amount of fuel you spill because it depressurizes the system. Otherwise, good write-up.
Sent from my myTouch_4G_Slide using Tapatalk
L
lamordnt
Aw man, great idea. I wouldn't stink like gas right now had I known that. Nice tip!
king_yukon
CANADA
Great post Iamordnt, figured I'd just check out what was up on here to make life a little easier. I've done a few fuel filter before but any additional info helps.
Also Domin good call with the relay, didn't think bout that one either. Kept most of the fuel off me this time haha
animalfries
I bought a new filter last summer and finally did mine tonight because of this post. It took me about 15 minutes. Thanks!
For other fuel filter virgins...even if you pull the pump fuse a TON of gas will still pour out! Definitely not a garage worthy task.
Big Buttons
The SS Burb
South Texas
When you pull the fuse your supposed to start your truck and let it die then go on and change the filter. When you do that it gets all the fuel out of the line. If you pull the fuse and don't start the motor there still fuel in the line...
lilsolo68
tyler,tx
ive changed my own filter before and its very easy. i tried to change my buddy's 2003 tahoe lt and couldnt. his filter had a nut on one end and a quick release on the other. we went to the parts store to get the special tool but we couldnt get it to work without breaking/modifying it (its a plastic tool). they had som more expensive metal ones but they were only 30 bucks, lol. he ended up taking it in to a shop to pay them and have it done "right". anybody run into that problem yet?
animalfries
Hmm. I pulled it while it was running and it died within 10 seconds. I figured it would have ran longer than that but just figured, welp, let's do this.
That must have been my problem.:)
denali00
did mine today, didnt see this thread, but i managed it on my own, pretty easy job! i took the fuse out and took the gas cap off..not sure if that helped. didmt spill that much gas really, maily whatever was in the filter already, and what sprayed out be the pressure released..
new2yukon
So I got the relay pulled, started engine and it killed right away. Loosened the gas cap and opened the fuel lines up and fuel came out and never stopped. It was as if the tank was just slowly emptying via the rear line. Couldn't figure why....made this a pain to do.
Why oh why would it drain from the rear line and NOT stop? Bet it drained 1/2 gal before I could get it done.
...what's going on so the next time it is easier? Wouldn't the tank be under a vacuum and prevent draining? Did loosening the gas cap cause my problem?
scoobyxj
Ummm... Bingo!!
Duramax05blk
NH
all these filters coming out no one must be from new england lol. I have never been able to get a filter off up other than my duramax. i am having to install all new lines to change the damn filter jealous!
01SLE
Replaced mine today, thanks for the tips.
I don't think it was really clarified but remove the gas cap to relieve the pressure in the tank, then tighten the cap back up! Otherwise you'll sit there siphoning out fuel like the poster above.
new2yukon
Weird thing is that's what I did....I loosened it and then tightened it back up...but got continual draining.....
So the answer is to NOT touch the gas cap???? According to a post above...
CKendrick
