Alignment after Drop
NathanJax
Vacation Nathan
Jax, Fl
How often should a Tahoe/Yukon have an Alignment done after being dropped ?
If it's a good shop, once.
I get mine done every 6,000 miles.
Seriously?
So around every oil change or so your getting your truck aligned? I hope you're not paying for it.
If you've already had a proper/correct alignment, it should not change alignment until something in the suspension wears out or is damaged. Alignment doesn't change. The only thing that changes it is wear or damage. Hitting a pot hole or a thousand pot holes won't knock your suspension out of alignment unless you hit something hard enough to actually bend metal. That really doesn't happen very often, so having the wheels aligned periodically is a waste of money.
mharders
Just outside of Seattle
No I do not pay for it, I take it to a buddies shop. I guess I should of been more clear. I'm basically just checking if it's to spec every time I get my oil changed/tires rotated. I dropped my truck last year and only needed it done after the install.
NathanJax
Vacation Nathan
Jax, Fl
:Handshake:
casmier14
casmier14
San Jose CA.
So i bought some 26's 4 months ago and had the front dropped with belltech spindles and didnt even think of an alignment... last week, i noticed my tires were bald and had to buy two new front tires... learning from my mistakes...damn...Thanks for the info guys....
felixgun
Lafayette, LA
Oh wow. Yea anytime u lift/drop or change suspension for that matter, you definitely need an alignment.
Modded
That Guy
Anytime a suspension component is altered an alignment is typically recommended.
After that it is not needed unless you hit a pot hole or curb that throws the car out of spec.
Last time I got an alignment was in March 2010 after I installed drop spindles. That was 10,000 miles ago and I have had no issues through the 3 set of wheels/tires I have gone through since.
RoliO
Dallas, TX
Can someone point me to where I can find the alignment specs for a 07 Tahoe? I'm lowering mine soon and would like to know the numbers. Thx!
daygooz3v
i get mine done every 2 months but i bought a thing at firestone that has unlimited alignments
RoliO
Dallas, TX
I didn't think they still did that unlimited deal. Every 2 months might be overkill but then again you have to get your $$ worth. :D
THE YETI
Director of Operations
South FL
anytime I change my tires out I get it aligned. Between going from stocks to 24s all the time, I guess this averages about 3 times a year...lol
Hodmjstone
