DJM arms
Omar
do i need to buy DJM shocks with their arms
or i can run stock shocks
i read somewhere that only djm shocks will fit
so i sent them an email
they replied that i dont need their shocks
is this a new design?
NORCAL SS
SUV SUSPENSION GURU
you can use stock shocks but they bottom out easy and ride wont be as good at all. If you can do it id buy it all at once.
I sell the arms and shocks djm and beat anyone's prices. If you call djm and talk to them mike answers the phone and ask him about tony the trailblazer guy he will tell you to buy from me. Lowest prices around and back it up with 24/7 support.
O
Omar
because in the pics i see the mounts are different than stock
MeanGreen03
TX
Yes, unless they changed the mounting point it takes an eye while the stock shocks are forked. I could never find any cross references from the DJM shocks. At the time, when I was looking, none of the shock companies had any of the shock specs (i.e. compressed/extended lengths and mounting types).
NORCAL SS
SUV SUSPENSION GURU
nothing changed same design just its a different set up from factory arms.
O
Omar
im more confused now
please explain..
can i run my "stock" shocks rather than djm shocks?
from reading around and pics i found that i need djm shocks
when i sent them an email they replied that i can use the stock ones
is this some kind of new design?
NORCAL SS
SUV SUSPENSION GURU
you can run your stock shocks but will ride bad.
The djm shocks are shorter and valved better than stock shocks thats why its better to go with the djm shocks.
There is no new design I have over 30 sets of arms here with production date of last month nothings changed.
You can use the stock shocks but ride is not good at all.
O
Omar
how can i use my stock shocks if the mounts are different?
NORCAL SS
SUV SUSPENSION GURU
Save yourself the problem get the new djm shocks with it. you can try to use stock shocks but fork design on stock ones is not the best at all trying to make it work.
NORCAL SS
SUV SUSPENSION GURU
the last time i used stock shocks on djm a arms was prob over 10 years ago. Ever since then due to the ride issue and customer being upset at me I will not install the djm a arms without getting shocks. If i remember correctly the forks were wider than the djm a arm mounts and i used a sleeve in the center.
Sorry just was soemthing i tend not to deal with anymore.
if your going to do the kit omar just get new front shocks.
MeanGreen03
TX
Yes, get new front shocks. I tried to use a stock type of shock and the mounting part that bolts to the control arm broke off of the shock. It was probably due to no rubber to help damper the shock.
O
Omar
thanks for the info guys
i just put a new shocks so i was thinking about a way to keep them
well.. i guess i will wait
NORCAL SS
SUV SUSPENSION GURU
Finished another customers truck today. You can see lower shock mount is totally different on the djm set up
Alex33
This is a great pic. A lot of people should benefit from this. I am thinking of swapping in these arms but I just bought shocks four months ago and I was hoping they would fit. Clearly they don't, but now I know what to get when I make the switch.
O
Omar
i also bought new shocks.. thats why i was asking
i guess i have to wait
thanks tony anyway
vsaravia
