Looking for a set of led Daytime running lights
DuckHunter
Senior Member
Arkansas
I am looking for a set of led daytime running lights for my 02 yukon, preferably that blue white, or bright white color. I have 10k hids so w.e would macth more closely to those would help. If anyone could shoot me a link to some or the bulb type and number it would be much apperciated. Thanks
steven johnson
wisconsin
LEDLights.com - replace all my lites (inside,outside) no problem with them. they been in service for a year .
A623Z
Phoenix, AZ
Had mine for little over a year now, no issues. I did install some resistors inline with +wire on the harness though. The running lights on the ends are switchbacks :)
tsb09000
Thread Killer
What size/type resister did you use? I'm not familiar with resistor lingo so any part numbers would be helpful.
Thanks!
SHWELL
Florida
What does Switchback imply? I see they have dual colors, but does that have a use as DRL?
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
Hey I have an issue about 3157. I had just went to swap my DRL lights on my burn found that there was 3157's in there and the completely fried the bulbs and the bulb mount spots all the white area is brown and burnt looking. Now the new bulbs wont work. I just got Sylvania LL ones.
DefendHawaii
Snake Eater
I got a voltage meter so I am gonna run it through. If all else I will cut some out of a JY Tahoe that is local and then wire those in. I need a ton of stuff from there but gotta wait til the 20th.
SHWELL
Florida
My Yukon has the 4114's right now. And there is Browining on mine as well. But still functioning.
elcapitanmas
I bet if you ask around most will tell you the same about their light sockets, I replaced all my lights all around last week and all had stock bulbs in them, sockets were CRAP. everything still works though.
dizhai
