Eclipse AVN5500
fast_jason
I just purchased an Eclipse AVN5500 for $90. All i got with the unit was the main wiring harness and iPod adapter. It did not come with the Video input/steering wheel control wiring harness. What does this do and do I need it?
Is there a sleeve that goes over the unit for installing with the dash kit like single din units? If so, I don't have that either.
I'm also looking for a map disk if anyone has one or can burn me a copy.
BeaverGod
steering wheel control is enabled by a seperate interface unit that runs about a hundred bucks at a store. PAC audio makes one model SWI RC. you need to program it however and the resistors require soldering to work properly
it would enable you to control the volume, see through radio/tracks, and in some cases select sources. the options depend on the vehicle
Bigsteve04Ho
I bought an avn 5510 and I had to order the other harness off ebay.you must have it for the park brake wire and rca outputs
Tozer
