Problems:
Changed interior lights to LED. When opening door or just interior is lighted up, all lights come on just fine, super bright. When inside vehicle and doors closed, inside lights go out and you want to use the push button, (dome light) per each side, front or rear passenger ones. When manually pushing the dome lights, they are only half lit up. Not at full 12v power. Only at full power when using the dimmer control to full max to make all interior lights come one, manually push lights, half Dim
Solution:
What angel.arteaga posted with the relay. It does in fact work. When manually pushing the dome lights, they lit up just like normal, full brightness. But problem with this is, when inside lights go dim, (for instance when doors closed) the relay buzzes, like its going from 12v to 10 to 5 to 1 etc. Slowly dies. lol. Then the other problem is, that sometimes when the interior lights come on, the one light, (the side) you put the relay on, that one light goes dim, just like theres nothing on it. Half lit. So you have to manually push that one light w/ the relay to have it come back on full power. Then all is good again.
I can try to get a video of it, not sure how its going to work, but hey worth a shot.
Solution:
