Sierkonblazer
- Joined
- Nov 21, 2011
- Posts
- 139
- Reaction score
- 1
Finally... Well, maybe not completely done. Im still trying to figure out a decent way to make a new shroud. For now, these Panamera's will work. It wasnt as bad as I thought it would be. Had a few oopsies along the way, but I figured I would, so I prepared for them. One major one was I put the projector in upside down. I figured the "brow" for the high beams would go on top (which is wher thee solenoid is), so I installed, glued only half of the projector into the reflector bowl, then found out during a test fit and fire that it was upside down.. I forgot that the convex lenses refract the light in opposite directions.. But it ws nothing a little Dremeling couldnt fix. Other than that, the only issue I currently have is the wiring harness sent from TRS has the high/low beams backwards. Andrew at TRS dropped a new harness in the mail yesterday when I called him, no questions asked, so I definitely praise their legendary customer service.
The Trailblazer is definitely next for a retrofit, after doing this one. Night and day difference over the stock POS headlights.....
