Adjustable pedals
Jimartina
Hey gang new here. I bought a 2003 yukon Denali short wheelbase. The only problem is that the adjustable pedals don't work. Can anyone give me some advice about these. I have never had them be for. They are retracted all the way in. (as close to the dash as they go) which is great for me i'm 6'2" but my wife is only 5'3" so I would like them to work. ANY and ALL help will be greatly appreciated. thanks.
ps. heated seats and power seat functions all work.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
welcome aboard. 1st off. did you check fuses? That be the best place to start.
Jimartina
Jimartina
not yet. no manual. so i don;t know where anythign is, or which ones to check.
JochenWoern
Sacramento, CA
Welcome to the forum. :)
Unfortunately, I do not have the "adjustable pedal" feature in my Yukon and therefore my Manual will not help. However, I am convinced that one of the guys here will chime in and let you know which fuse/fuse # to check.
Good luck!
Jimartina
Jimartina
Good luck!
thanks I'm sure they will.
JGARZA2213
Valparaiso, IN
I have the adjustable pedals in my 03 Tahoe, but unfortunately they do not work either. In the manual it says that the truck must be in park for them to move, with key on, but for me, it still doesn't work. Give it a shot, let us know.....
Jimartina
Jimartina
I'll try that TY
Jimartina
Jimartina
ok update. When I push the pedal adjust buttons, the relay/solenoid clicks. but nothing happens. is there a way to test the motor? can just the motor be replaced?
M3PO
Mid West/Cow Town USA
Not sure,
First, look under the dash and make sure nothing looks like it is bound up.
Test power at the motor. If you have power there, I would think you have a bad motor or something else is locked up.
I tried mine yesterday and it sounds terrible, I need to go under there and find out why it sounds so bad, so I am not in your shoes later down the road.
Jimartina
Jimartina
Not sure,
thanks for the help. i will check it out. hope u get yours working smooth again. maybe you just need some lube or some sort... i tried to pull mine while pushing the button.
13mpg!!!
Any luck getting those pedals unstuck? I just purchased 2004 Tahoe AWD with adjustable pedals. After bring it home and giving the car a going over, I adjusted the pedals using the arrow switches in the door just to see if they work. The motor whined but moved the pedals into the closest position to the driver seat. When I tried to adjust again nothing. Now the motor is not engaging, but I'm hearing the relay click as you did. Any help?!
hii'mjon
Same boat. There's not a lot of threads about this. Perhaps its a rareity. Someone save me and tell me where to start.
JGARZA2213
Valparaiso, IN
Has anyone came up with a fix? It'd be nice to get those damn things going!
---------- Post added at 06:23 PM ---------- Previous post was at 06:22 PM ----------
Tahoes are either 2wd/4wd, never AWD. Only the Denalis have AWD I do believe.....
scribble
PM me your e-mail address and I will send you the section from the GM service manual.
ghellmold
I have the same problem in my 2004 Suburban. When I push the pedal adjust buttons, the relay/solenoid clicks but the gas/brake pedals don't move.
I am a newbie so I cannot yet PM to request the section from the GM service manual.
SuperDad
Same problem here! My 200 Yukon XL, When I push the pedal adjust buttons, the relay/solenoid clicks but the gas/brake pedals don't move. I replaced the Adjustable pedal sensor and that didn't do anything. Also my drivers side heated seats won't stay on. Someone said I might need a new switch module on the drivers door?
Drewphil
