im thinking 2/5 drop
bosworth496
Mira Loma Ca
im thinking a 2/5 drop for my 07 hoe... i dont like the rerun of all the drops i have been seeing...
Modded
That Guy
Good luck with that.
It's going to look pretty stupid when your rear end is about an inch and a half lower than the back unloaded, talk less of if you're loaded and towing.
But maybe you like the Cali Lean look.....
bosworth496
bosworth496
Mira Loma Ca
Yea I do like that look I'm from so cal no stink bug for me and all do tow bags just like I did my truck in my pic no need to be a dick about it bud...
Modded
That Guy
I wasn't trying to be a dick I was just saying don't try and be different and end up regretting it.
I had like 1" of Cali Lean for a month back in Jan. 2010. Everyone kept asking me if it had bags in the rear because the front was so high.
Modded
That Guy
I have a 3/5. And sometimes it even looks like its leaning to the back even though measurements show the front is about .75" lower.
NORCAL SS
SUV SUSPENSION GURU
usually with the belltech 2/4 kit the rear sits 1/2 inch lower than the front. DO you want the rear to sit over 1 inch lower in rear than front?
bosworth496
bosworth496
Mira Loma Ca
i was thinking about a 1" lower in the rear i like that look i mean norcall what can we do i have talked to a lot of companies about lowering my tahoe and i've been getting the run around with it because of the way i want it to sit so i was going to make my own kit with the help of the guys at go ez customs..
SWSS
Smashville
WOW has the styles changed! I understand wanting to be apart from the rest. A couple of the 4X4 shops around here put a little nose bleed on the lifts. Some of us mounain boys would do the same type of drop but we shoved some fatties under the back to level it out... bottom line - its your ride and your money - be happy with it.
HeavyHoe03
