01 Tahoe 45mph Wobble
xxlosts0ulzxx
Apple Valley, CA
Problem: Front Driver Tire/Steering Wheel Wobbles Around 40-45
This been going on for a few months now and im sick of it, i did replace the inner tie rod because the old one was busted. ive tried searching but cant seem to find an exact fix. Do anyboby have one?
Thank you in advance
Edit: posted in the wrong one please move
LI99HOE
Top Notch Tech.
N.Y.
Just spit-balling on this, but here's a few possibles to check out.
1-Improperly balanced tire.
2-Problem with the tire itself..possible separated chords within the tire(swap with one of your other tires to test)
3- Bad hub bearing
I'm curious though.... how do you know it's the drivers tire doing it? You driving like Ace Ventura?? lol
X
xxlosts0ulzxx
Apple Valley, CA
3- Bad hub bearing
lol yeah one day i did it because a driver next to me, told me that my tire was wobbling
Rivieraracing
Dumb question for you but gotta ask anyways, are you sure all the lugnuts are tight and the rim is sitting square against the hub?
pablo63
How about checking the upper and lower ball joints? Mine use to cause a problem / wobble around 55-60 mph and would go away below or above that speed. Just a thought and easy enough to check.
brifee4
I have the same problem with my 2002 yukon. wobbles at 45 and feels like the front end will fall off at 75. Checked shocks, bearings, pitman arms, all suspension. Bought new tires, had front end aligned. Drives like crap! I can't figure it out. It also "grabs" the road and yanks u into groves. Not fun to drive. The only thing I can say is that I have 18" rims and wider tires. 285-60-18. This may contribute, but the wobble at 45 and 75 is not cool. Not comfortable letting my teens drive the car. I know this doesn't help, but maybe somebody will have an idea....
CKendrick
