Installed - Gmx550 Lockpick In 2008 Tahoe
plush
Ok, i just installed mine tonight. I was able toput it right where they show in the video (above the XM box). I ran the apple cord under the cup holder, cut hold in the center console and plugged in my iPhone.
Couple of questions:
Can you watch a video not only on the front screen but the pull down screen in the back?
It won't let me switch to DVD in motion, how do you change this? I can change to Nav in motion using the scroll screen but it shows DVD in motion, just won't let me push the play/pause button to turn it on.
Green Machine
Orange County, CA
You should always be able to watch a video on the rear screen. But yes, the GMX550 lets you watch the same video front and rear at the same time.
As far as your DVD in motion, something is wrong. It should activate the same way you activate your Nav in motion.
Do you have any other black boxes hooked up to the truck?
plush
DVD, hmm, do I need to hit any other buttons? Or should it just start playing?
Black boxes, no.
plush
All was fixed when i got my BB tune. Justin said that resetting the computer which is done, cleared up any issues I was having.
However, I am still having issues using some of the sterring wheel controls some of the time. Sometimes they work, others not.
vanvalks
Man this lockpick thing really sounds like a piece of junk, I think someone should disconnect theirs and sell it to me at an extremely discounted rate :)
Any takers?!
KMcCoy33
Installed my GMX550 yesterday in 2011 XL Denali. I was excited to try everything out and for the most part was pretty happy.
Then started seeing navigation issues. The signal loss from the GPS is normal from what I can tell when using any functions, but I did not expect it to occur after things have been turned off. It seems to take a much longer time to pick it up with this thing installed.
The worst part - the navigation system (not using any of the functions) seems to lose where I am. Today - had me about 8 miles back from where I actually was. Sometimes turning the car off will fix it. Other times, I disconnected the battery and then waited for the GPS to sync back to find me. My experience with the navigation post install has not been good.
I'll keep my fingers crossed that the issues get worked out, but after a firmware update or two, this thing might be coming out if I still experience the same issues. It costs too much to not feel good about having it in.
mikey42_69
I have the same problems with it. Turning on and off the car most of the time works but then you have to stop on the side of the road anyways and I bought this unit so I don have to stop. Right? Sometimes I turn on and then off then exit the menu then get back in and turn it on and off and exit. That fixes it Most of the time. If all else fails I have to tun on and off the truck. I have never had to disconnect the battery. I have a 2011 Denali. Also sucks that to play an iPod video it uses the rear view camera screen.
bmwme
No it isn't perfect but the only thing on the market with so many features and ipod control. Hopefully a future firmware update will fix some of these annoances. I have noticed that you HAVE to manually disable NAV in Motion even after you turn the car off and back on. The menu will say "off" but I've found turning it on and back off will fix the NAV issues most of the time.
On the topic of ipod control. Is there a way to change tracks with the wheel controls while playing MP3s stored on the ipod/iphone? I can pause and navigate the menu but I can't figure out how to change tracks.
felixgun
Lafayette, LA
The more time I have mine the more I hate it. And I have it in two vehicles too... I noticed it degrades the sound quality through my iPhone 4 via the 30 pin dock connector. Music at the higher octaves sound scratchy compared to just using an auxiliary 3.5mm cable.
Autbond
Has anyone else noticed that the iPod video nor the iPod interface for music works with iOS 5? I called the company and they said that they were waiting on Apple to come out with an update for video out and that was why it didn't work. Is this true, or were they just trying to get off the phone?
felixgun
Lafayette, LA
Mine doesn't work either which is an iPhone 4 (32gb) BUT for some reason my girlfriends iPhone 4 (16gb) DOES work... We are both on iOS 5 and non-jail broken.... I called tech support from coastal tech and they weren't helpful at all. I asked if I could update the firmware on the lock pick and they said no. Sucks...
felixgun
Lafayette, LA
On my iPhone I can't do it but on my iPod Classic 120gb I can change the tracks. So inconsistent...
THE YETI
Director of Operations
South FL
looks like that $1.99 mini plug wasn't such a bad deal...lol
KMcCoy33
Regarding firmware, I would like to think some issues would be fixed in the future. The question just becomes how far into the future.
My current firmware shows as 1.4z when I scroll through the menu options. I only see 1.3 on the USB Update page Coastal has. This makes me feel less confident in the company and quality of the product. Are these guys serious about what they release or is it just a "we have the best option" kind of deal?
Like one of the prior posts, the more I try to use this thing, the less I like it. It makes me appreciate my simple at-home bypass I was able to do on my Pioneer X930BT in my older vehicle, almost to the point where I wonder if it would have been a better idea to have the aftermarket system than the factory nav. It for sure would have been cheaper.
Again, you just don't expect to feel this way about something you drop nearly $300 on.
HartAttack
I have the GMX 550 and VCIM bluetooth swap in my 07 Tahoe LTZ with NAV and rear DVD. I have noticed some of the minor issues discussed here. Primarily with the GPS. I am also having a problem with video streaming. My Iphone 3gs streams videos saved on the phone no problem, but unfortunately I have been unable to get video streaming with some of my apps Netlix/HBOGo/NFL Sunday ticket. Anyone else had this issue?
On another note has anyone noticed that the XM tabs on the favorite menu go from the station name(ie Hip Hop Nation) to the XM number(ie XM 101) once the LP is installed?
BTW I have had to recently reinstall the LP after taking it to the dealership for some warranty work (got a new Nav unit out of it). The first install was above the VCIM which I do not recommend. Thanks to this thread the second install went behind the glove compartment right next to the XM unit. The wires provided by Coastaltech are easily long enough to achieve this. I would highly recommend anyone who is installing this unit to place it here. Much easier than stuffing it under the radio and causing problems with your AC controls.
hush569
Dallas, TX
i haven't had any problems with mine, the XM channels went back to numbers but if you resave them they go back to the names...
---------- Post added at 01:48 PM ---------- Previous post was at 01:47 PM ----------
oh and is the glove box easy to remove? i put mine under the flap near the gas pedal, fits great there and has easy access for updates (if there were any)...
THE YETI
South FL
Glove box does not have to be removed... You squeeze the back of it and it releases down out of the way.
felixgun
Lafayette, LA
Nope that's what I thought too. When I talked to Coastel Tech about a firmware update they said no they don't do those.
roger1079
So I found this thread in google after having some issues. I have a 2007 Escalade (Late 2006 manufacture date) with factory nav and the rear entertainment option from the factory. I have been having some issues with the GMX550 formware revision 1.4z. First off I put in a GMX322 right after I bought the truck and it worked flawlessly for the 2 years I had it installed. I never even experienced the nav tracking issues after DVD in motion. The worst it ever was would be about a mile off and it would snap back to my current location in a few seconds. I have been dying for on screen iPod control and when I saw the GMX550, I figured the upgrade would be worth it, and since I never had any problems with the GMX322, I didnt hesitate to upgrade. Needless to say, I am second guessing this decision now. The sound out of the iPod dock connector is horrible. I have tried every EQ setting available on the iPod and my radio and it crackles with any bass at all even at low volume. The entire stereo is completely stock by the way. With CD audio, XM, and radio it sounds great. I drove to work this morning and everything was fine. Getting in the truck after work, the radio wouldnt turn on. A few back and forth turns of the key and I finally got it to power up. Pulling out of the parking lot, the OnStar icon came on the screen and the radio went silent then started to feedback horribly. (I have never activated the OnStar in the time I have had the truck) The next thing I hear is the lady asking for a number to dial. Hitting the phone button on the mirror to hang up and right away it came on again. It proceeded to sporatically do this all the way home. All Lockpick features were off during this time. I got home and got out of the car and the radio went back into OnStar and would not turn off with the key out and door open. I finally got it to turn off and armed the alarm and went inside. I came back out 30 minutes later and the radio display was on again. I pulled the lockpick out and looked at all the harnesses for frayed wires but found nothing. I put the GMX322 back in and all is back to normal. I will be calling Coastal Tech tomorrow to see if they have any answers about the erratic behavior and the iPod sound quality.
Sorry for the long winded first post, but I am looking for any answers at this point as well as to share my experience with anyone looking at this unit. Hopefully they get the bugs ironed out with a firmware update soon. If not I am hoping for a refund and sticking with the less feature rich but stable device.
felixgun
Lafayette, LA
My Lockpick sucks too. I have the gmx550 in my 07 avalanche and 07 escalade and the sound quality is just as you describe it. Also, i'm on my 2nd unit in the avy. Within 65 days from date of purchase [for the avalanche], my LockPick unit caused my factory nav radio to completely shut off. A full black/blank screen with no digital clock display. When I brought it to the professional audio shop that also sells this unit (I bought mine seperately from Amazon.com from Net Electronics LLC) but installed mine, they tested it out and determined that the lockpick was dead and it singlehandedly shut down my factory nav. Since the radio would only work WITHOUT the lockpick, I took it out. I called Net Electronics and explained word for word what I just said above. They told me to issue a refund/exchange, I would have to call Coastel Tech, talk to a "specialist", and troubleshoot the issue. Once they saw the problem they would then give me an "okay" for a replacement unit. I re-iterated that the unit had already been un-installed which I paid to get done because their unit broke after only having it for a few weeks and that there was no way I was doing all of that. They said: "Well call CoastelTech and try to explain it to them and ask them to give an ok for your exchange". When I called CoastelTech per NetElectronic's instructions, they said "we don't give permission to 3rd party companies selling our product for exchanges"....... I was like WTF? After a back and forth for a few hours, I decided to claim an "A-to-Z Guarantee" through Amazon. Within minutes I got an email from Net Electronics saying that a replacement was on the way. I dealt with all this ASIDE from the unit itself sucking.
So TL;DR -- Aside from unit sucking itself, the vendor, and 3rd party vendor from Amazon (Net Electronics), SUCKS. Their product is buggy and their support is horrendous. STAY AWAY.
EDIT: You also mentioned a firmware update. I had called their tech support once before about my iphone not outputting the video and if their was a firmware update that I could be missing. He said they don't release firmware updates... EVER. So there you have it... no firmware update.. How ****** is that?
worleytrev93
