sagging rear
dre
the rear of my 07 tahoe is sagging........i had ground force 2/3 kit......i changed the front to belltech drop spindles and adjustable drop struts......the rear is still ground force. the rear is sagging due to (2) 15" orion hcca@ 90lbs each+plus the weight of the box. i need a solution. plus stiffer shocks for the rear...... thanks
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
spacers will help. I have a 1 inch that goes in between the bottom of the coil and the spring perch. I also have a 1.5 available soon after i install my 2' spacer
D
dre
added weight........any suggestions on stiffer rear shocks to support weight....possibly upgrading the rear suspension ........something new an upgrade from groundforce
CKendrick
