WTB: Wood Grain Window Switch Trim 07+ w/ Power Fold
Kolt-46
In the brush near the river.
I'm looking for the wood grain trim plate for an 2008 Tahoe with power folding switch opening. If you have one for sale, please feel free to contact me.
Thanks,
Shaun
StevenFromTexas
Mr. Negative
Lubbock, TX
I think the 2010/2011 part number is NOT the same as the one for 2007/2008/2009. So the fit may not be the same. What year Tahoe are you inquiring about?
THE YETI
Director of Operations
South FL
Shaun, did you get the quote I sent?
Kolt-46
Kolt-46
I did and thank you. I was able to find a used switch @ half price but it has an aluminum bezel. I just found out, after hooking it up, that it has white backlights instead of the green-blue like the rest of my truck. This DL3 project is getting bigger and bigger.
Were you able to find the other parts after I provided the VIN?
---------- Post added at 08:37 PM ---------- Previous post was at 08:36 PM ----------
i think the 2010/2011 part number is not the same as the one for 2007/2008/2009. So the fit may not be the same. What year tahoe are you inquiring about?
2008
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
I thought the window switch trim was the same because the only difference between DL3 and DL8 mirror switches was the addition of a button between the mirror select buttons and window buttons, thus the door trim would be the same. Am I wrong?
Sent from my myTouch_4G_Slide using Tapatalk
Kolt-46
Kolt-46
I thought the same thing. The blank space where the power fold switch comes through is "plugged" with a piece of plastic on the none power fold switch bezel. I thought it was a blank on the switch itself but found out otherwise when I went to swap it earlier.
ranorris2
The Coolest
McKinney, TX
Kolt-46 dont buy one...just cut out that plastic piece, thats what i did when i made this swap. You cant even tell i cut out the piece even if you were looking right at it.
CKendrick
