JochenWoern
Sacramento, CA
Pouring with rain so pic is ****** which makes tails look darker, but ...
- Newly properly tinted tails courtesy of mr supercharged ss
- Rear 5/8" spacers to line up the wheels to the arches
That's it for today.
LOOKING GOOD!
I am suppose to get my X3 LED Tails today, so I might be wrenching as well tonight. :)
bankswood
Lets see, todays project has been changing the transmission fluid and filter...
Lets just say I've got that good Government Motors feeling,who the ........Puts a shift bracket and exhaust cross over pipe so close you cannot drop the pan without moving one or the other?WTH is wrong with the engineers? My S10 Blazer and Bravada where easier to change than this full size truck!!!!
First of all a 1/2" difference on either one would save the hassle of getting to the bracket bolts on top of the trans (S10 and Bravada bracket uses pan bolts)...Or just alittle more clearance on the cross over pipe would allow manipulation of the pan and out...But Nooooooo....
Not to mention the previous owners service department must have used an air gun on the drain bolt(must have missed the torque wrench class).Had to go old school and tilt and drain the pan as I didnt have a new bolt on hand....I am shaking my head in case you couldn't tell.lol
That being said I am glad all the fluids and filters are fresh going into winter :)
The next trans service I will have a new drain bolt on hand and will heat the bolt with the pan off of the truck and remove...
It should have been easier..:emotions122:[/QUOTE
It is exactly what happen to me. I was not able to replace the filter. How did you get that done?
THE YETI
Director of Operations
South FL
more folks would probably see this if you posted in the right thread... :nono:
dwmmatt23
central valley cali
Finally got my white face cover in and after adjusting how hard I push the needles on three times it works flawless without sticking. I used my Garmin with echoroute that displays all my gauge info in real time to check the needle replacement accuracy and they are all dead on.
THE YETI
South FL
No... just vomited reading these findings on the Sandusky case. :vomit:
LuSe4
Bleen Member
Michigan
Looks great. Where did you get it?
Oshkosh
Marblehead,Ma
I ended up using a large pry bar and tweaking the shift cable bracket after removing the shift cable from it...I didnt bend it anymore than needed so I could get it back into shape when finished....
I hate working like that but looking at the corrosion on the bracket hardware and the thought of dropping my drive shaft for access I chose to go that route.
If I have to do this to many more times I will burn together a new shift cable holder that will utilize the transmission bolts to hold it like on the Bravada that I just serviced....
05Yukon23
Arkdelphia, AR
Refreshed the vent covers with some krylon fusion gloss black. Looks much better. They were faded and just not up to par. Also finished my roof rack with the satin black. Looks better to refresh all that stuff. I'll post pics tomorrow, it got dark. Next on the list is the onstar antenna to refresh and the frame since it peeks out from under there a little.
OHSIXX
Milwaukee
Nothing exciting...washed her up since while I was out running errands it decided to snow very heavily and made all the roads wet.....just enough to screw up a clean ride. Tomorrow gonna send out my cluster because a few of lights decided to go AWOL....
JochenWoern
Sacramento, CA
I am suppose to get my X3 LED Tails today, so I might be wrenching as well tonight. :)[/QUOTE]
LED Tails came in and installed. I am very pleased!
Tahoewhat
Ballin' on a Budget
TX
What you going to put in it? White? i want pictures when done. ha ha..
LED Tails came in and installed. I am very pleased![/QUOTE]
looks good. Same ones alot of us have, but looks much cleaner w/ them.
JochenWoern
Sacramento, CA
looks good. Same ones alot of us have, but looks much cleaner w/ them.[/QUOTE]
Yes, I think it looks awesome. Thanks.
Oshkosh
Marblehead,Ma
Umm, clayed everything but the roof and put a coat of cleaner/wax on it.
Pumped my p/s res out and refilled with fresh...
Alex33
Pulled off the compressor for my autoride setup, no longer need it. While I was out, I measured my truck again. It's getting very close to 30" even ground to fender up front, it's at 30.25" and sinking. I may have to raise it a bit :eek:
Hodmjstone
