jdpber
GOLD MEMBER
The America
Vacuum and clean windows.
Cut my 0gauge wires for big 3 and started soughtering the terminals. Will install tomorrow.
LI99HOE
Top Notch Tech.
N.Y.
Seafoamed @ the throttle body for the second time ( I think it might have solved the sticky valve problem). So far much smoother, better mpg, and no code P0306(prayin' :shocked:)
Put plug wire seperaters to finish up the job when I changed to
Autolite(AP605) plugs, and AC Delco wires.
I put up a new sound clip of the exhaust
http://www.youtube.com/watch?v=fsBrp4DDCZc
jdpber
GOLD MEMBER
The America
Pics of 0 gauge big 3
Crimped in vice and
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Stupid question big I have been searching for a big three upgrade for nbs on google, search on tyf and have come up dry anyone have a hot to link they could share? I can't pull anything up on this for some reason :shrug:
Sent from my iPhone 4S using Tapatalk
jdpber
GOLD MEMBER
The America
It is very easy.
1) fire wall ground to te ground point on the alternator bracket
2) (+) alternator to (+) on battery
3) battery ground to chassy. I chose the bumper bracket. Clean the paint off for a good solid ground.
That is your 3 main wires. Use 4 gauge at minimum. I will PM you pictures of the install tomorrow if this description didn't help you enough.
Tahoewhat
Ballin' on a Budget
TX
Here ya go.. (dont search NBS, just search your year and you'll come up w/ more. NBS isnt to google friendly for me either)
http://www.tahoeyukonforum.com/forum/showthread.php?t=1349
http://tahoeforum.com/showthread.php?t=7828
http://www.tahoeyukonforum.com/forum/showthread.php?t=114
http://www.gmfullsize.com/forum/showthread.php?t=106041&highlight=big3
those should help ya out
Alex33
I opened a lot of boxes and then decided to wait for another day, haha.
swtz71
Mass
I ordered my replacement rear backing plates. I ordered the split style..
also washed it then drove down my ripped up road and got it all dirty again..
jdpber
GOLD MEMBER
The America
I installed the BiG 3 and filled up washer fluid. Along with re aligning my slight sag of front bumper on passenger side.
gdddup
NJ
post up some pics when you do it. i bought the same style plates over the winter and never installed em.
Max
Mile High
Denver
Changed engine oil/filter, tire roto/rebal, greased everything, switched out some front bumpstops, cleaned my aem filter, rewired all my power leads to new top and side post terminals, wired up some nitrous stuff...still waiting on the controller :flame:
01HDtahoeNJN
North Jerz, NJ
Got my Led swithback leds 6000k/Amber turns signals...and there not working like tere supposed to...smh:flame::Good or Bad:
before:
After:
JochenWoern
Sacramento, CA
Installed 20" inch Yukon Denali NNBS wheels, including Bridgestone Dueller Alenza HL Tires, 275/55R20.
Merch619
