Steering Wheel Trim Writeup
Ben
PCB, FL
To go from this... :Plugged:
To this!!!
Tools:
Torc 30 and Torc 15 sockets
Needle nose pilars
Long skinny allen wrench
Stick the allen key in a small hole to release the airbag, there is one on each side, its recommended to disconnect the battery before doing any of this but it's not necessary and can be completed fine without it.
The airbag will then release and the mounts will make much more sense once you get a feel for where the clips are with the allen key. At this point disconnect the airbag with the two clips, you can't mess it up they are color coded. Use the needle nose for the airbag wires, but dont press hard.
Remove the four large nuts with the torc 30 bit, they will not come apart from the main bracket.
Then disconnect this wire.
Here is what it looks like removed.
Remove the four ground contacts for the horn.
Then remove the radio and cruise control controls if you have them. Then reattach them to the new trim pieces.
Should look like this.
Reattach the trim pieces.
Reattach the bracket that holds the airbag and wires.
And finally press the airbag back into the clips until they lock, if you didn't disconnect the horn it will go off.
Hope this helps!
ChrisAU
Birmingham, AL
Where can you get these? Would LOVE to get a hold of a couple of these pieces in woodgrain!
rpuddy
Thanks! I didn't need to unhook the airbag - just set her on top of the column.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
I could use a little help on step 1. I've been using a long allen key, as instructed, but can't seem to figure out how to get the front cover and airbag off the steering wheel. Is there a specific item I'm suppose to feel for, or do I need to push or pull a certain way? Is there a trick I don't know about that I should be using? Any help would be appreciated.
Sent from my myTouch_4G_Slide using Tapatalk
NC_John
North Carolina
Over 2 months after my last post in this thread I am pleased to announce that I finally made it past step #1 and have now completed this mod. Thanks for the writeup and help this thread provided.
I haven't done mine yet but need to- the original covers are peeling (I know, I know- shocking). What was the answer to your question- is the allen key just used to push and release a clip or is there an allen screw in there?
Ben
Ben
PCB, FL
Hey sorry for the SUPER late reply! All the allen key does in step one is release a pressure clip. No turning involved. It's not the easiest task either.
NathanJax
Vacation Nathan
Jax, Fl
Tell me about it. Just tried it. Felt like 10 minutes of poking around in the dark. Always getting the wrong hole. Not hitting the hole quiet right. Then bam, done.
story of my life...
NathanJax
Vacation Nathan
Jax, Fl
i cannot get my air bag out!
:laughing1:
just keep poking the hole. seriously. Took me like 10 minutes and I had an extra wheel to look at to see what i was kinda poking...
Durobans
