3rd row seathing question -- for a non-equipped truck
strad
Las Vegas
Mine is a 99, and it does not have the 3rd row seating option. I'm wondering if anybody knows if the brackets for the seat are under the carpet. I can feel hollow areas in the places where brackets should be, but without pulling the carpet I won't know for sure. Anybody know?
I just notice that the headliner looks like it is set up for third row seating already -- and I'm having trouble believing they put a different floor in depending on whether the truck was going to have third row seating or not. . . .
lummy
they're custom only for the OBS. I had to buy special mounting brackets and then cut holes in the floor pan. Also, the burb 3rd row uses 3 point seat belts and can't be used in the Hoe. I bought 3rd party and I did use the cargo mounts for the seatbelts.
S
strad
Las Vegas
Aww schucks. I was hoping the solution would not involve cutting holes in the floor. Not a problem though if I decide to do it. Would you mind telling me where you got the brackets? And did you just grab a 3rd row seat from a GMT400 suburban, or can you use others?
lummy
The seat came out of a burban. Not sure about other trucks. I know the second row won't work tho. The 3rd row has to sit in between the wheel wells.
I've seen them on ebay every once in a while for $49 but couldn't find them when I needed them. I think the place I got them from was www.theseatshop.com. They'll have the seat belts too
Ceejkay
Ft. Lauderdale, FL
please search for my name in general you will find your answer. the kit is 1200$ but no cutting is required
johnd8695
Where did you buy those mounts?
TejasPitt
