a7x4life2005
- Joined
- Sep 9, 2011
- Posts
- 2
- Reaction score
- 0
I recently bought a 2001 Yukon XL and didn't know it at first, but it has headlights issues!
My Yukon had projector beams installed before I bought it. And, for some reason my high beams stay on all the time but are EXTREMELY DIM until I click the high beams on and only the RHS becomes bright while the projectors and LHS high beam goes completely out until I click high beams off and they both go back to being dim again.
I was thinking it may be an issue with the projectors, so I put stock headlights back in it and completely did away with the entire projector set up. No difference at all. Both low beam and high beam are still staying on together very dim.
So, I called up the guy I got it from and he said he put in the projectors himself and that's when the issues started. He played "none the wiser" after that.
Should I be checking the headlight switch, underhood relay, splices in wiring, dirty/corroded plugs, bad/loose/broken grounds etc.. or?
ANY help at all on this would be much appreciated!!!
