Can oversized tires mess with my speedometer
PKFL
I have a 2004 AWD Yukon Denali that orignally came with 265/70 17 tires. I just put 285/70 17 tires on it and now the speedometer is not working. Is this something that can be fixed?
Splatmaster527
Cleveland, OH
Well bigger tires will surely make it read different than it did before but it should still work...
Do you mean it seriously doesnt work or its off by a few MPH?
gdddup
NJ
bigger tires size wont make the speedo not work at all. but throw it off like your truck is reading 55 and your doin 50. which you can fix with a tune or programer
P
PKFL
It just stopped working all together after about 2 days of it reading off about 3mph
jem556
KY
Your problem is not likely due to your tire size but a result of a GM design flaw that causes speedometer/cluster gauge problems to be common in GM NBS tahoes & yukons. There was a factory recall issued but to qualify for free repair, you had to have less than 80K of mileage if I remember correctly. There is a cottage business of folks doing these repairs...
P
PKFL
Thank you sooo much for your help. I completely forgot that I had read something about that. It was just such a weird coincident that it happened right after I got the tires so it didn't even click.
Is there any possibility you have any ideas on where to find the info on do it yourself kits?
Drewphil
