Which drop springs???
BlizzardX23
Sacramento, California
Im trying to buy some rear springs right NOW!
ok..I wanna lower the back of my truck since I lowered the front..
Can I just buy new springs for now? and install them? Shocks are just for ride quality/comfort right? All I need to do is install the rear springs to actually lower it?
and how easy is it to swap springs? how long does it take? and again, can I use simple hand tools?...can it be done in a parking lot?
what all do I need to buy to lower the back...JUST two new springs? and what brand...DJM? what are they...5 inch? and can I paint them? lol
coopiesb
wichita falls, tx
i would suggest shocks the ones ur have r designed for a certain travel and lowering it will change that you could probably get by for a while but ride quality will be degraded.....
BlizzardX23
BlizzardX23
I know I'll NEED shocks...but I can get shocks when I get back to Cali...I wanna do the springs now just to get it lowered now
coopiesb
wichita falls, tx
i havnt done it on a tahoe but on a civic and it didnt ride very good...... i dont have much experience but you should be good temp..... but long term i wouldnt suggest it
blueflamed03
Oklahoma
if you have autoride, that will change it up some. I say get shock relocators, new shocks (if not autoride) and Eibach coils. If you don't have a spring compressor, I suggest letting someone do it.
BlizzardX23
BlizzardX23
oh yea...thats for sure...Im not leaving it...I just want it lowered before I leave Ft. Sill..I want it lowered by this weekend...
so....Just springs will do the job? which brand? How do I get the old one out?
55belairtim
i have the mcgaughys springs ride good, lots of guys on this site use them, you need to change the shocks or get shock ext the shocks limit the travel of the rear end. if you dont use them and the vehicle becomes air born the coils can fall out.
thank you tim
matt14
san leandro,ca
The ride on my 5" springs from djm is solid. Its not really "bouncy" just solid. If you go with a 5" drop, cut the bumpstop brackets out. This will be a great time to do it. I have heard some good things about Mcgauhys. May want to try them out.
BlizzardX23
BlizzardX23
issue...when I look at the kits...they all say for 2wd only...
I want the most drop...more then a 2/3
which Mcgauhys kit would I use? Im not seeing it
matt14
san leandro,ca
Hit up 55belairtim. He's an vendoor here and has mcgaughys. Also you can hit up norcalss, he sells djm. They can get you the right info.
Fyrcaptain
Richmond, VA
Hey Coopiesb....your sig says you have the GF 2/3....but your sig pic looks like
stock height?
NORCAL SS
SUV SUSPENSION GURU
i can get you 2-5 inch drop springs and all DJM Items
NORCAL SS
SUV SUSPENSION GURU
i usually get rid of autoride due to the fact that wiht 5 inch rear drop the shocks are way out of their effective range. Its up to you i sent ya a pm on price :)
lowest for sure shipped anywhere
BlizzardX23
BlizzardX23
http://www.streetpros.com/product_info/category_id/7/subcategory_id/143/products_id/62787/
will that kit work perfect?
its 3-5 *FOR AWD*
# Front Spindles
# Front Torsion Keys
# Rear Coil Springs
# Rear Axle Relocator (whats this for?)
# Sway Bar Struts (whats this for?)
---------- Post added at 09:02 AM ---------- Previous post was at 08:52 AM ----------
I will be ordering a kit THIS week....I DO need a complete kit
I want spindles for the front as well..3 inch if possible.... (I AM AWD)
NORCAL SS
SUV SUSPENSION GURU
for 5 inch rear drop i really dont recommened the airride system to stay in. For the rear kit i like the djm one because it comes with new sway bar brakets to keep all that in check which is needed when going so low.
are you set on that?? the djm 3/5 honestly is a good kit and id stick to 2/3 if you want to keep autoride in.
sidenote here is the rear djm kit as you can see it shows why the kit is needed on your truck
http://djmsuspension.com/Instruction PDF 0908/Kits/RK2000.pdf
BlizzardX23
BlizzardX23
honestly...I just want it low...5 inches lower...if I cant keep the autoride, **** it...I wont...(does that mean it'll bottom out/tuck when I tow a boat?)
the link you sent me in PM didnt work =/
vsaravia
