air ride kits?
waxworkz
i only have one comp as i am only bagged in the back right now. i made my own mounting plate as i didnt want to spend the cash for the mounts. i also like working with metal and learning to weld. i might redo it if i have time, which most days isnt in long enough bits to do anything
Young28
The Yukon God
ga
engine driven is where its at for air. i dont have it since i added the supercharger.
BLKCaddy
Houston, Texas
Heres how mine looks, i cut out the spare tire holder
ILLEGAL REGAL
Tinley Park, IL
Got the rear bags installed and cut the bumpstop bracket off. It rides so much better than the 5" springs did.
I've still got to do the leveling arms/sensors and tack the lower cups in place.
It airs out not as low as I hoped, might look into different lower bag mounts as the ride tech kit has the bags maybe 3" above the axle tube. But playing with different heights I've found it rides best very close to where it sat with the 5" springs. After I get the front done and figure ride height I'll debate changing rear brackets.
Now one odd thing happening is when aired down the pass side sits lower. Any ideas? I'm going to look it over closer tomorrow
ILLEGAL REGAL
Tinley Park, IL
Found the pass panhard mount is sitting on the sway bar. No idea yet how to fix that other than longer links or notch the bracket. It has a dim hardware kit.
waxworkz
what size rims and tires are you running? what psi does your bag sit at 5"? mine sits at 5" at about 38-40psi
NASTY GM
Nor Cal
Here's a pic of my set-up.
waxworkz
damn thats a sic sub. mine looks no where near that nice. is that at ride height?
ILLEGAL REGAL
Tinley Park, IL
The first pic is with a 5" spring, 2nd is aired out resting on the sway bar. I've got to figure a way to get it down more. Ride height is about the same height as the first pic.
I'm thinking about changing or modifying the lower cups if once I get the front done and it's ride height won't be higher than the rear.
waxworkz
really mine sits way lower than that aired out and i have the same kit. but i have hotchkis sway bars front and rear. i havent done the free travel mod yet. maybe tomorrow or sunday
ILLEGAL REGAL
Tinley Park, IL
Some pics, all up and all down.
Sway bar links undone to show how much it holds it up
The lower cups. The part rounded to fit the axle tube is supposed to be touching to get welded. Not really close
The axle to frame gap I need to close up and gap between panhard mount and crossmember others who've done this say hits.
varminpoolteam
