wish I could say I have done something to it, Its been sitting waiting for me to get back from vacation.....
2005yukonxl
are you the one i read a while ago, about something in the sterring column sounded like the front end is going crazy. I read that post somewhere and was wondering what it is to change, mine does the same thing. i think the post said something about changing it every 20k or so. Cant remember exactly.
If this is what you got changed, could you find out what it is that got changed, mines not bad, but bothersome.
thanks
i think they all eventually make the weird noise. i took it in thinking it was going to be the intermediate shaft but it wasnt. It had already been replaced by the previous owner and another GM dealer. They said it was a noisey steering column bearing and also a noisey steering gear. other than that, thats all i have. i'll look at the invoice and see what part number it was.
but the intermediate shaft is the one that is kinda a change it when you change the oil type of thing it seems...well maybe not that bad but certainly a bad design.
scarpi
Phoenix, AZ.
Took my 02 Yukon to the dealer and got the cracked AC belt replaced, cost about $143. With temps in Phoenix soaring you don't want your AC belt to break. About 54,500 on it and still runs and looks like new. Love my 4x4 Yukon.
rosendo192000
Installed OEM fog lights on my LS and wash and waxed
gdddup
NJ
more info on this please. thank you sir
i bought these cheap aftermarket fogs n the one was fogged n half full of water. i just ran a bead of clear silicone where the lens n housing meets after draining drying and cleaning the fog
ghostworks
Norway
Changed airfilter, freshairfilter, gasoline filter, engine oil and transmission oil. Lubed front and rear suspension.
Now she'll run clean for a few more miles :)
made an appointment to get rid of that stupid grey inside my black on black tahoe.... also getting different bowties color maybe color matched with outline that matches my bike or maybe C.F. ones... we shall see....
Phantomx55
Slow
New Jersey
Have the same problem with mine and was planning on doing the same thing to fix it. Run into any rainstorms yet to test the new seal?
Anyways, cleaned my throttle body..no more rough idle :)
scarpi
Phoenix, AZ.
Bought new tires. Went with the highly rated Michelin LTX MS2. Seems that everybody that has them loves them.
gdddup
NJ
it rained pretty good the other day no leak as of yet. but my truck was parked
Max
Mile High
Denver
Need to wire it up and I'm waiting for jets. Only have 100 jets, gonna start with 50 and work my way up until the trans starts to get grumpy. Then I'll build the trans and go up until the engine gets grumpy.
puckhead
CO
Ha! I like the way you think dude. Cant wait to see the final project.
jdpber
GOLD MEMBER
The America
drove past the truck at the mechanics shop getting repair from accident.. the rear brake assembly was off and the old axel out.. she is getting a new: axel, caliper, rotor, diff fluids.. then to body shop and paint.. then the wheel and tire shop
Rabu XL
Ruined my stock taillights with an old can of VHT nightshade....:banghead:
New LED tails that I really can't afford in the mail...Hellooooo credit card debt.
Nortex
Painted chrome grille white and hauled 4 sets of wheels back rubbing on every bump
wwiizz
