Front Dash Crack
conservatony
Add me to the list: 2007 Yukon 38k miles... just walked out to find a 7" crack running through the "hump" above my steering wheel.
Just bought it used a week ago. It's 70 degrees in AZ today. Absolutely no reason why this should have happened.
RBagans
Another cracked dash.... Mine has 2 cracks now one at the airbag area and the other just to the right of the driver side intrument hump... GM people have not been helpful at all to me... I have over 100k miles on my 2007 Yukon... even though mileage does not have an impact on the dash they are coming up with varying excuses of why not to help...
rjnkajun
Luling, LA
Refresh my memory ...... What year is yours and did you have an open case number with Chevrolet?
i choose to go threw GM and let them schedual my appointment so the dealership knew GM was aware and i would hope not give me a run around.. so i had a case number 1st ... then i coudlnt get ahold of my case manager so i called all teh numbers i could untill somone helped me line up the apointment and told my case manager to get back with me within 24 hrs becouse i had an apointment he had to follow up too. I brought mine in and the service guy was like let me guess another dash? so i kinda knew they would fix it right there!
and the service guys at BRYAN Chev are all awsome they really took care of me and never once tried to get over on me!
BLK07LT
Man I have a 07 Tahoe with 38k and I hope that I don't have this problem feel bad for anyone that has had to deal with this problem.
Vig03
07 Yukon Denali: GM repair denied
Just got a call from Customer Service at GM and was told that GM is unable to provide assistance with the cracked dash. They told me they were not able to determine the cause of the crack.
I told them that was a poor excuse since the cracks were in the exact same locations as other dashes they have repaired...
My Denali is an 07 with Mocha interior (Dash is brown).
tonyt013
I have the same crack on my 2007 Tahoe on the left side of the hump in front of the steering wheel. I also noticed the bulb covering the ambient light sensor appears to be missing. I am beginging to think some ******* got into my tahoe and removed that sensor and in doing so damaged the dash. Perhaps at the car wash???
Hope this has not happened to any of you as well.
adam p
Tampa
I have the same 2 cracks in my 07 Tahoe. theres a long thread on another forum about everyone getting it replaced and the problems with various dealerships. That and teh black wearing off the a/c power button is bothering me.............
07Z71hoe
Hey slydoghoward I'm also in GA and have the crack in the dash. Im wanting to take it to the dealership this week
DYRTIGAF
Yes...I just recently noticed a crack in my dash as well. It is just above the steering wheel to the right of the coutoured hump. I was looking online and also found another post from another Tahoe owner with a picture attached showing the same exact crack as mine. Manufacturing defect ? I have taken very good care of my Tahoe so I can't believe this has happened.
Just bought mine used and is cracked at the hump above the instrument cluster but to the left hand side, also cracked on the far passenger side near the pillar. Makes me think just some cheep Chevrolet plastics.
RickyFriery97
i have a 2007 NNBS tahoe with the exact same two cracks everyone is talking about,
i bout it used in august of 2010 with 38k on it and it had both cracks when i bought it
im going to talk to a dealership about it, i really want this fixed but not out of my pocket,
my parents have a 2010 yukon with i think less then 20k on it with no cracks but im sure it just a matter of time before it cracks...
2005yukonxl
u bought it a year ago with 38k miles...was out of warranty then....and now its way out of warranty and you think the dealer is going to do anything? u should have done it as a condition of sale back last year, they could have good will repaired it...but aint no one going to do it now this late...
RickyFriery97
its under a extended 5 year/ 100k mile warranty
rjnkajun
Luling, LA
try to find others in your area if your local dealership wont help u.. if u see a tahoe in the parking lot someplace look at its dash take photos leave a number. GET together and go to a dealweship one at a time eventually they will crack NO PUN INTENDED! we had a few guys fromt eh New Orleans area that was willing to go all at once but we happened to find a dealership willing to fix the GM FK UP! dont stop untill they fix it!
04ctd
Charleston SC
how many miles/years out were you?
I think the dash is being used as a "strength member"
in other words, when you go over a diagonal road bump,
the left front tire jams up, and causes "cowl shake" which is where the cowl area takes the brunt of the impact, because our trucks do not have Strut Tower Braces to share the impacts from side to side.
i think the Dash does not have room to wiggle, and it breaks at the weakest points: around the airbag (thin) and around the display hump.
if you have ever ridden in a convertible, and crossed train tracks that are diagonal, you can usually see the cowl/dash move around.
the dashes in the GM Camaro's had the same problem.
maybe it's saving weight by having a too flimsy firewall, and the dash is taking the load instead of the firewall?
it's just a poor design by some young engineers at GM who have not been in the industry long enough to know about cowl shake and torsional rigidity
Srbucy
Same Problem Fleet Vehicle
I have a 2007 Denali that is 1 of 6 all purchased from the same dealership in San Antonio,TX. Mine developed the crack about a week or two ago. Mine has 47k on it so I knew the warranty was a no go. I had originally called to get a purchase order for a door handle. That broke. Our fleet guy called me back and said out of the 6 in our fleet. He has had 8 door handles replaced. I then mentioned the dashboard crack. He was hopping mad about the door handle already. I guess I would be too considering we spent some $300k on 6 vehicles.
He has not seen any cracks in the other vehicles. However he told me to prepare for a fight at the dealership. I took it to the dealership here in Vegas. Talked to the Service Manager about the door handles. No problem. Free of charge. Then I showed him the cracked dash. He said he had not seen that before. However he said that if I paid the first $100. They would take care of it. Done deal.
I am impressed that with no warranty at all. They were willing to do this! Awesome service!!
I then called back my corporate fleet guy. He couldn't believe it. He took the other 5 denali's to the dealer that they were purchased from and they would only bear 50% of the costs on the door handles. He is afraid to see if anything will be done if any more of the Denali's in Texas develop this dashboard issue.
Seems very inconsistent. But now it sounds like since the service is so good in Vegas. He will be purchasing our next 30 or so vehicles we get a year from the Las Vegas GMC dealer!
CBFHTOWN
I have the same issue on a 2008 Yukon with a crack in the dash right behind the airbag. I just recently purchased it used. I was initially wary that it was the airbag that had deployed in an unreported wreck causing the crack(no CarFax issues). However I've been in the collision business for years and the body/frame is mint. No repairs or I would have noticed...
Now I'm starting to get the idea this is a common problem and can let out a little sigh of relief. Fortunately it's under warranty and they are replacing the entire dash.
mturnerua
Alabama
I just had the dash of my 07 Tahoe LTZ with 111K crack above the airbag a few weeks ago. I got GM customer service's number from Elizabeth on here. She said to take it to the dealer and see what they say. They said there was no bulletin, hadn't seen it before, blah blah blah. I asked for a quote and said I had been in contact with GM. They quoted my $721 plus tax. I told Elizabeth who had me contact GM and they took my info and sent it to the customer assistance center. A few days later I received a call from the district manager who told me they had seen it frequently on Silverados but not as much on Tahoes. He said something about they had been replacing them free on Silverados with less than 70 or 80k miles on them. He said for me they would cover the cost of the parts if I would cover the labor. He said it would be about $237. So I guess I'll do it and try to have it done next week.
oakland0830
az
I took my 2008 Yukon Denali into the dealership this morning to talk about my dash crack...This is the second time it has crack and its in the same position. My service guy looked at the truck and said it was not a problem to fix the dash since they have already changed it one. I mention about how hot it is here in AZ and if that was what was causing the crack and he said that it is due to the design of the dash and also the material, He also mentioned that hopefully these newer dash are build with stronger material so this problem doesn't keep occuring...He told me he would call me later today, and i just received a call saying that they could replace the dash on Monday, unfortunately i can't take it till Wednesday but as long as they fix it....
BadDaddy2003
