Annoying Screeching Sound From Rear
AMG ETR
Ok so I have a really annoying screeching sound coming from the rear of my truck and I have NO IDEA what it is... Basically when turning right (even slightly) I get a metal on metal type sound from the drivers side rear wheel area. Turning left it does not do it, if I keep it perfectly straight it does not do it, but the second I start turning right it makes noise. I changed pads/rotors and that did not help (needed to be done anyway, was just hoping that would solve it).
Does anyone have any idea what it could be? The fact that it only happens when turning right is whats stumping me... Thought diff or wheel bearing, but either of those shouldn't be effected by the direction the truck is turning...
Thanks for any help!
Evan
PS- Still having the ABS/Traction Light when turning either direction, maybe this is related? I haven't taken it in for the "Slow turn ABS" service bulletin yet tho...
Upstate
Ask for your wife to get out of the back seat, it should go away then. j/k, sorry - couldn't let it pass.
GM Customer Service
Michigan
AMG ETR,
Have you been into your dealership yet for this issue? It is possible the bulletin you’re referring to could be the issue. I advise you to speak with your dealership to confirm what the exact issue is.
Thank you
Elizabeth, GM Customer Service
02Lightning
Maybe a heat shield that needs bent away from the rotor...
A
AMG ETR
Upstate: HAHA
GM Cust: I have not been to the dealership yet, but I will look into it soon.
02: Checked that, and it only happens when turning right, which is very strange....
GM Customer Service
Michigan
AMG ETR,
If you take your vehicle to the dealership, please let me know what they have to say.
Thank you
A
AMG ETR
AMG ETR,
Thank you
Will do! I also have the chrome pealing off my door handle issue like everyone else, so hopefully they will cover that...
Evan
GM Customer Service
Michigan
AMG ETR,
Thank you. I look forward to hearing what your dealership has to say and if you get your vehicle fixed.
Thank you
A
AMG ETR
Ok so I threw my truck on a lift and decided to diagnose the issue myself and found it. The issue was one of the caliper "clips" (that the pads slide into) was barely touching the rotor on the outside. Therefore when the truck turned that certain direction and the axel/rotor assembly shifted that tiny bit it would contact that piece and make the metal on metal sound. So that issue is finally solved :)
Now onto the ABS/Traction Control issue and chrome door handle pealing issue (both will have to go to the dealer). Will make an appointment soon!
Evan
GM Customer Service
Michigan
AMG ETR,
I am glad to hear that you got one of your issues fixed. Please let me know what your dealership has to say about your other issues.
Thank you
glazar
