Removing bird crap
3blackchevys
New Jersey
My story is that some bird decided to take a massive dump on my blazer a few months ago. Was never able to get it off and decided to clay bar and wax. Worked good.
before:
after:
Chris
I burn it off with a propane torch
Chris
Nah man its real easy, you can also use one of those razor blade holders and heat the blade up with the torch to aid in poo removal, also if you cut yourself it well self cauterize the wound
road1will
pretty pretty good
Johns Creek, Georgia
i take the torch directly to the bird crap, then scrape it with the razor blade. if that doesnt work i just rub it with a little paint thinner or brake fluid.
Chris
True, I forgot to add the paint thinner part, I find paint thinner to be too harsh sometimes and will use mineral spirits most of the time. I'm not sure if this is a secret but I have found soaking the spot in brake fluid, then igniting with the torch will help break down the organic compounds much quicker, follow this up with a razor blade to remove whatever remains, this has always worked perfect for me.
