stock amp location?
02YUKON
Oxnard, CA
i have a 2002 yukon where is the stock amp located? and it does not have the bose system it has the rear subwoofer though
rc610
Bulldog Country, Mississippi
I want to know too. i'm not even sure if i have 1. I have an 03 Tahoe. I do have the bose system but as far as i can tell there is no (factory) sub in the rear.
GeneralNoobzor
Phoenix, AZ
Try removing the cup holders, get a flat head screw driver and pop them out. Look under the center console, an amplifier should be there. Put a flash light on the right side behind the center piece. At the very front by the passengers feet. Go to the drivers side and look for the light shining through. A subwoofer is usually between there.
Mondo
Did you ever find it. I am wanting to do an amp bypass.
Sub
For 2002 models that are not Denali, the amplifier is mounted vertically behind the glove box. Drop down the glove box by squeezing in the sides of the glove box walls until the back tabs ciear the stops, and the amplifier will be visible as a large aluminum heat sink with a single connector plugged into the left side of it.
If you your 2002 Yukon XL is a Denali, with RPO code Y91, then the amplifier is behind the left rear quarter panel trim. This is the same trim panel where the subwoofer is, only the amp is mounted on a separate bracket ahead of the wheel well. You can access the wiring without pulling the entire panel by simply lifting the snap in tray where the jack and jack tools are located, on top of the left rear wheel well. The Denali amp has two harness connectors, facing the rear.
ccapehartusarmyINF.(ret)
Gilbert AZ
no need for bypass
you dont need to by pass the amp if your just installing an aftermarket deck just make sure connect the power ant wire in the harness that will turn the stock amp on
if your doing aftermarket deck speakers and amp your aftermarket speaks are going to go straight to aftermartket amp and dont connect the power ant wire in the harness
Angela
I have a 2001 chevy tahoe i found my factory amp with the wires clipped on top of my sub in the back of my tahoe don't know where it goes (when I bought the tahoe the sound worked and then cut out only comes on every once in a blue moon) I was trying to figure out why and what was going when I found it. Can you tell me were it's supposed to be located at and possibly why my factory radios sound keeps cutting out like this?
briannorris
