Lifting with autoride?
20tahoe01
I'm a noob when it comes to tahoes, and trucks in general. I just bought my hoe about 2 months ago and am verry happy with it. After seeing the lifted rides of some of the members on here I've decided to go with the famous, ford keys in front and rear spacers. Also I'm. Noticing that with that "2 lift they get the 5100 bilistein shocks. My question is, since I have autoride should I take it off or is it better to leave it on? Thanks in advance.
Max
Mile High
Denver
I would remove the autoride, just disconnect the battery for a few minutes and pull the RTD fuse under the hood. Install the bilsteins and you're ready to rock.
20tahoe01
20tahoe01
Thanks for the reply. I had read somewhere that unpluging the autoride fuse it will also disable other components such as the heated seats... etc.
20tahoe01
20tahoe01
Also just heard about this rough country suspension leveling lifter kit, spacers keys and shock for 269.99! Sounds like a good deal to me. What do you guys think?
polobuds
East Bay, CA
ive heard not so good things with rc kit. some people say the rc keys are basically stock keys, the shocks are cheap, and the spacers are 3/4", which dont do anything.
options are to get ebay keys & spacers and some bils. Or just crank stock keys, buy spacers and bils
20tahoe01
20tahoe01
Thanks for your honest opinion, I was thinking that it would just be cheaper to go with ebay keys and spacers.. is the pump underneath the hood where the secondary battery tray goes the pump for the autoride system? Ill try and take a picture of it later but its in the corner of where the antenna goes.
andrix
What about the autoride on a denali/escalade? Is it any different? I know that it will show up as text on the dash instead of just a light correct? The resistor kit should work just the same as a tahoe or yukon im guessing to remove the message.
chevy_man
Great Falls
Why anybody would do the resistor kit when you can just pull the fuse is beyond me. As long as you unhook the battery before you pull the fuse you don't get the dash message.
The fuse runs the compressor and that's it. I had the fuse pulled on mine for a few months while I was sourcing a compressor and I never found anything else inoperable.
The compressor is under the rear cargo area, behind the drivers side tire bolted on the frame rail. Just loosen the bolts and slide it up and to the side. It sits in slotted holes on the frame.
PUGLIA
Oklahoma
? For Levi? Have you replaced your rear shocks with something else and your fronts? You are the only one I have ever heard of that just removed a fuse from this system and never had a light pop on. Everyone I have talked with from custom chop shops to lift manufacturers have told me either you must fool the system with a resistor kit(which I have) or you can disable the system and have the your ride reprogramed with the codes left out.
All I ever hear you talking about I's the compressor and the auto leveling in the rear. What about the electronic dampening for all four shocks? What is the fuse for the compressor going to do about that?
JoeRider
I've got an 07 Chevy Tahoe LTZ 4X4 bought it new back in 07. I'd like to put about a 4" suspension lift but I don't want to lose auto ride. Any suggestions?
TN_Tahoe
Check out Ebay. I got a 3.5" front /2.5" rear kit for my 2010 Tahoe for 140.00
Chano Garcia
If I’m wanting to do a six inch lift kit. Can I use one that isn’t for Autoride if I’m ditching the Autoride? Are the coil springs or anything different in the two models? Or anything else different besides air ride shocks or conventional shocks.
vsaravia
