Question about Air Conditioning and MPG
WhoDatPanic
How much does running the AC really affect the mpg in our tahoes ? does anyone know for sure? if it does or not i know i have heard it could be a myth or if it really is true ? Also how much could it drop mpg ? i usually get around 13 ish in city per gallon and never run the AC but its starting to get African hot here and would like to run the ac but scared it will significantly drop mpg's.
ezdaar
Chat Troll
Redneck central, Aka Houston
Run it, dont worrie about it.
If anything install some electric fans, or a simple pusher fan to keep the radiator thing cool when idle at lights and stuff.
OBS Denali
Ohio
They say running the AC uses the about the power of 1 cylinder from your engine. I dont know how that translates into mpg, but that may give you an idea of how much power loss you take when running it, and how much harder you're engine will have to work to replace that power to provide you with the same type of driving that you do.
Gordy
Not enough
To make me rather sweat my balls off when its 80 plus hot, and humid.
Thats like having an ice cold barley pop in your hand on a hot summers day, and afraid to drink it because you'll have to piss.
But to answer your question it depends on engine size as to how much it will effect MPG. The smaller the engine the more drag on the motor. Larger CI engines will see less of an effect. Either way you will get less MPG.
As for the 1 cylinder theory thats about 35 HP I find that hard to believe. That would be about 261110 watts, or 26.1 KW Most home central air systems do not use a quarter of that wattage.
Cheers
LI NewYork
they did a similar test on mythbusters about driving on the highway while running ac and driving on the hgwy no ac with windows down.it averaged out to be pretty close to the same mpg either way.
waxworkz
the rule i have always heard and go by is, anything above 40 mph and having your windows down is more wind resistance drag than the ac drags your engine. i run my ac all the damn time now that i have my efans, i must say it gets colder faster, stays colder and i picked up about 2 mpg with my fans and tune. i can also do 70 mph on the freeway, with the ac on, hauling a loaded 17 ft 4 horse trailer and 4 adults and 1 kid
Jay
The relationship is probably one cylinder at part throttle.
It takes 30-40hp to keep a modern full-size SUV at 65mph on a level road. Doesn't matter what engine is making that power, it just takes that much to overcome wind drag and tire friction to maintain the speed. To that point, in a V8 each cylinder is making 4-5hp.
FWIW, I've never seen more than 1mpg difference in running the AC. Traffic conditions (speed, congestion, number of stops, etc) will dictate mpg far more than the AC will.
edgaranah1
Corona California
Yeah i saw that show too. I always have the ac on I would rather pay a little more and be comfortable
M3PO
Mid West/Cow Town USA
This is what I have heard from several different sources. That said, the OP sounds like he/she might be talkingmore stop and go driving so he/she might not be reaching those cruising speeds. My guess is in stop and go traffic you might only notice 1-2 mpg loss.
I have no research to back this next statement up; this is just MY guess. I use the "recirculate" option when I use the A/C in hot weather. My guess is, if you are not continually pulling hot outside air, rather pulling the already cool air from the cabin, your A/C compressor doesn't have to run as much to keep the cabin at a set temp. I'm sure there is not much difference if any, but its only the push of a button :)
Jay
The real tangible benefit recirculate has is to remove humidity from the air. Humidity offsets the effectiveness of sweating/cooling down. This has a huge benefit when you have a car full of sweaty people.
If it's 95* outside and 80% humidity, on regular AC that humidity gets pulled into the car with a little removed by the condenser as it's cooled. On recirculate, the same air in the car is recycled numerous times, removing a little more humidity each time until it gets very dry to where you need to blink your eyes more often (but you'll feel cooler due to your own sweat evaporating much faster in the drier air).
But, in terms of mpg, there is no real effect on regular vs recirculate. The discharge pressures from the AC compressor will not change enough to make a large difference in the power required to turn it.
adrianb
Longview, WA
I have been tinkering with different things trying to eek out every mpg i can. I drove with AC off for a couple days and watched my average MPG, there was zero impact. That said, it hasn't been hot here by any stretch so the AC might not be in use very much.
I drive the same route every day so I feel pretty good about my test.
One thing I will say: I also removed my roof rack's crossbars and definitely am seeing a slight mpg improvement - maybe 1 mpg.
Run your own test. Drive with AC on, reset your average mpg number. Turn the AC off, reset the mpg value and see if you notice a difference. Definitely report back.
Jay
I prefer calculating by hand :). Reset the trip meter each time you fill up and use the fill gallons and total miles driven at each fill up. Most accurate over the long run. Also make note of any errant events (longer idle times, more traffic congestion than normal, etc) over the course of each fill.
The best way to increase mpg would be to lower the truck as much as possible, run shorter and narrower tires with light wheels (like a 27 or 28" tire versus ~31" factory tires... yes it will look funny on these large trucks), and install taller axle gears to make up for the shorter tire and further lower highway rpm cruising. Obviously, driving slower helps if that's an option. Target for ~1500rpm at 65 in your tire/gear calculations.
Beyond that and you're looking at engine swaps. I'd be curious to see what a tahoe or yukon would get with the Mercedes 3.0L V6 diesel and GM's own 6L80E six speed auto (GM should offer a package like this IMO). My guess would be another 5 mpg or so over a 5.3.
waxworkz
Some of the stuff you guys are suggesting, engine swaps, tranny swaps are not worth the investment vs moneys used to run ac. If you think about cost of an engine swap, unless your engine is blown, it would make more sense to drive with the ac on all the time! I have spent about $600 on tune, efans, install time and I only netted about 2 mpg increase. Sure the ac, power and the like are cool, but was it really worth the money spent vs the end result?
Point is, if you don't have the money to fuel the truck/suv maybe selling it and buying a smaller car would be the best option? I tow 2-3 times a week and can not do that with a small car. So for me the money spent on fuel is worth it because I am making money. If it's hot, I run the ac, gas mileage is not as important to me as being hot and uncomfortable. Especially after having worked a few hours in the sun.
04SS99Denali
NY
if your THAT concerned about MPG you shouldn't be driving a truck of this size with a v8
WHITEOUT
Dont Hate-Appreciate
Phoenix
I saw episode also and in "real world" actual driving, it was a pretty big difference actually. They got like 40 extra miles or something like that. Ya on a computer test they did, a/c on actually got better mpg then windows down no a/c. ???? Real world driving with a/c on windows up you will loose mpg compared to no a/c on. I personally loose about 2 or more mgp in the summer. Livin in AZ you gotta use a/c! But I personally try to roll down windows n turn off a/c whenever possible to save some gas.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Run the dang thing. Kinda hurts the ears driving over 50 mph on the highway, all windows down. Myth Busters Did a segment on this. At highway speeds you are best off closing the windows and sunroof, because opening them often causes enough drag to offset any savings from turning off the air conditioner. When driving slowly around town, where drag is less of a factor, keeping windows and sunroofs open typically uses less fuel than running the AC.
Of course, the most efficient car is one with the AC off and the windows and sunroof closed. Using the car’s vents might circulate enough air to keep you comfortable on days when the weather isn’t particularly hot or when the car’s interior hasn’t been preheated by sitting in the sun.
Jay
We know. You were supposed to snicker and ponder. :Caffeine:
WhoDatPanic
WhoDatPanic
well thanks for all the responses, i guess i will do some own tests too how much do efans cost and what is the benefit?
04SS99Denali
NY
e-fans can pull more air when your truck is moving slow like in traffic or slow city driving to keep it cool. also you wont have the drag from the clutch fan anymore. you can find a kit from anywhere to 2-500$ from i learned its better to spend the extra cash and get the right shit the first time
dizhai
