Knock sensor replacement help....
ryangt
double team supreme
Jacksonville, Florida
Ok so im getting the standard " my engine got wet to many times" knock sensor CEL on my truck. Its been on for over 6 months now, so i dont think its going away anytime soon.
I want to replace the sensors, but noone seems to have a good writeup from what ive seen.
I am more than willing to tackle the project and do a write up, but im trying to compile all the necessary parts to do the job before i tear my truck apart and have no other transportation.
So far, all i know i need for sure is:
2 x knock sensors
1 x knock sensor harness
1 x tube of silicone
i am not sure of any other parts, or if the intake manifold gaskets are the reuseable type or if i need those as well.
any help would be great
thanks in advance
Gordy
knock sensor
Have you tried to clear the code? Did you wash the engine when then the code appeared.
I say this because I got the same codes after washing my engine. I cleared the codes, and after a couple of tries its never came back. I have an 01 with 125k on it.
Just rying to save the hassle.
ryangt
ryangt
double team supreme
I cleared the code more times than i can remember ( i carry a code scanner in the truck ) and it keeps coming back.
I offroad the hell out of this truck, it sees alot of water crossings, some at the hood level, so its probably just about time to replace them
one to many water entries i guess.
Volant1
Volant guy
Upland, CA
On a tahoe knock senors are like fuel pumps its just a matter of time tell yours goes bad
91RS
GA
You will definately want to replace the intake gaskets, you can leave the throttle body installed so you don't need to replace that gasket. You can also leave the fuel rail/injectors installed if you disconnect the fuel line or you can take it off and swing it out of the way and not disconnect the line. If you take it off make sure to lube the injector seals with some silicone lube to keep from rolling/tearing them going back together. Spend the money now and go with all GM parts so you don't have to do it again any time soon (if ever).
ryangt
ryangt
double team supreme
sounds like exactly what im going to do. Nothing but delco stuff gets put on my truck.
BadDaddy2003
