Brake upgrade questions
sparg93
Expedition Tahoe
NJ
I might be able to shed some light on this...i have a '99 4dr and did the swap from 1/2t calipers to 3/4t calipers.
http://www.tahoeyukonforum.com/forum/showthread.php?t=19943
Also, 2dr tahoes have 10" drums, 4dr hoes have 11" (i'm not familiar with police packages).
If you only upgrade to the 3/4t calipers w/o hydroboost or master cyclinder upgrade, it's a COMPLETE waste of money; smash on the brakes, you will know what I mean.
Also, you should go with the 3/4t pads IMO. You will need to grind off the inside of the metal bracket attached to the pad b/c it will rub the top hat of the rotors, but it is definitely larger then 1/2t and more friction is always better. If you already purchased 1/2t pads, I would imagine staying with them is fine.
Here is my setup:
Cryo PowerSlot Rotors
3/4t Hawk LTS pads
3/4t AC Delco Calipers
Blue Brake Fluid (name is escaping me)
SS lines
My thoughts:
SS lines are worth dog shit for our applications (as you mentioned earlier). If they tighten up your brake feeling, it's b/c the brake lines needed replacing to begin with. The 3/4t calipers have noticeably larger pistons and 3/4t pads are noticeably larger.
Some folks have upgraded their master cylinders (larger piston/spring) and they commented it tightened things up dramatically, but caused SIGNIFICANT effort when smashing the brakes (not as safe). There are a few cases where folks upgrading to the hyrdo setup and they fell in love their system afterwards.
A full hrydo setup when done by yourself is about $700...a few writesup are on here.
IMO, a hydro setup would have a significant benefit over rear disc conversions. Rear brakes are doing very little stopping compared to the discs up front. When you smash on your brakes, you will notice the brakes aren't even close to locking when you first smash them...i.e. not enough "power" going through the calipers to clamp down on all that mass.
So, if you simply upgrade the rears, I feel you will get very little benefit b/c you're fronts are not exerting enough clamping for as-is. If you hydro the setup and still want more stopping power, then upgrade the rears and I'm guessing you would see a few feet knocked off your stopping distance.
The hyrdo vs. rear conversation is based on research and my opinion. The front conversion advice is from actual work I performed.
I hope this helps!! I'm going to hyrdo my setup this summer and will definitely post all the numbers for everyone to see.
AtomicHoe094
Atomichoe094
cleveland, OH
the disc to drum is more for looks IMO. i hate those ugly ass drums and will take the ease of working on discs alll day long. Thats mainly the reason why i got the SSBC kit, sells for 1300 bucks got it for 300 then i bought slotted rotors for that kit which was 250.
if you want more info check out this thread
http://www.truckinweb.com/tech/0807tr_ssbc_truck_force_10_brake_kit/index.html
sparg93
Expedition Tahoe
NJ
nice - i agree, the look of the rear discs is a great improvement over drums!!
AtomicHoe094
Atomichoe094
cleveland, OH
thats probably about it too! haha i still keep the factory Ebrake cable which is still positive as well. The calipers are actually from like earlier fords and such. They say "Varga" on them.
retorq
Kingman AZ
Stock Before Lift
Pressure-tested at stock caliper: 900 psi
50-0 mph: 90 ft.
After Lift
50-0 mph: 138 ft.
After Installation Of SSBC Truck Force 10, Two-Piston Front Brake Kit
Pressure tested at caliper: 800 psi
50-0 mph: 128 feet
After Installing Hydroboost
Pressure tested at stock caliper: 1,200 psi
50-0 mph: 98 ft.
Umm WHAT?! After a two piston caliper and more pressure you need almost 10 feet more room to stop then you did stock?!
2K6TBSS
East Bay, CA
The way I am reading this is the final stopping distance is lifted, with 2 piston calipers, and hydroboost. It looks to me like the stopping distance was better my almost 40 feet.
I would have liked to see what the stock stopping would have been with the 2 piston and hydroboost.
sparg93
Expedition Tahoe
NJ
Yeah, i read it the same way...hydro boost knocked of 30ft.
Very cool that he measured PSI at the caliper, it completely makes sense!! Smash on your brakes @ 50mph (stock config) and it feels like there isn't enough pressure grabbing the discs...add hydra and the extra hydrualic push on the calipers increases their grabbing strength.
---------- Post added at 01:00 PM ---------- Previous post was at 12:59 PM ----------
Retorq - where did you grab that data from? Which member posted it?
---------- Post added at 01:05 PM ---------- Previous post was at 01:00 PM ----------
I would bet money that when I upgraded to the 3/4t calipers my pressure at the disc decreased too b/c I didn't upgrade the master cylinder or go hyrdo.
With the two piston design mentioned above (prior to hydro), PSI dropped from 900psi (stock) to 800psi (two-piston). I would imagine the cummulative piston size is larger with the two-piston then the 1/2t (stock) caliper....larger pistons take more hydraulic fluid to close them.
Do my thoughts make sense or is there something else at work here?
steamroller
The South
And even though pressure at the caliper dropped the stopping distance was 10 feet shorter. :deal:
So, the big measurements will be:
1) Stock
2) 3/4t calipers & 3/4 pads
3) 3/4t calipers & 3/4 pads & stainless steel lines
Subjective statement:
The pedal has firmed up a little bit at the top. The big difference I've felt is after the first few inches of pedal travel the truck stops faster...you can feel the calipers/pads grabbing harder then stock.
In your thread when you first switched you said there was a difference and now you are saying there isn't. Which is it??:confused:
sparg93
Expedition Tahoe
NJ
The piston on the 3/4t is larger so I believe the same overall force is being applied...just to a larger area, effectively decreasing the PSI. That would be my guess...any ideas? Maybe b/c it was only 100psi the braking distance decreased...but at like 600psi, the braking distance would increase. If we could vary the psi, it would be a fun experiment!
Yes, at speeds around 30 - 40mph the above statement is still true; rig seems to stop faster (never measured though). I should have done more testing before I made the statement you quoted, but with the horrible weather, it wasn't practical to "test" them out.
On my updated statement - I noticed the weekness when i smashed on the brakes doing 60mph (first time about a week or two ago). It feels as though the calipers aren't strong enough to slow the disc down and they're not grabbing hard enough. Now, we all know 3/4t calipers are powerful enough, but I don't think I'M exerting enough force fast enough through the pedal to get these monsters to clamp down...I think any normal person would have this issue b/c of the extra hydraulic fluid that needs to move through the system.
With that in mind, I started to more seriously investigate the hydro systems and it started to make more sense. As an example, if you were to slap 1t calipers and not hydro your brake system, your foot would literally hit the floor pushing the extra hydraulic fluid from your stock master cylinder to the larger piston.
Anyone more familiar with brakes than me that can comment??
steamroller
The South
Where did the 600 psi figure come from? Wouldn't 2 54 mm pistons effectively reduce the pressure more than the bigger than stock single 80mm piston? Maybe I'm not thinking about it the right way.
Just to clear up the confusion I'm not saying that a bigger piston caliper will get you stop on a dime brakes in a 5500+ lb vehicle. Yes hydroboost will net a bigger gain at a much bigger cost. I don't consider replacing 2 rusty/used/abused calipers that are 12-15 years old a waste of money for what they cost....mine were under $75....don't know what you paid. The stainless lines cost me more than that and did absolutely nothing.
Have you tried pulling the ABS fuse yet?
retorq
Kingman AZ
Yeah I see that it took 40 feet of, which is awesome but it's still not doing what it did stock ... wonder what it would do on a lowered truck. :rocking:
The link Adam posted, 2nd to last page in the article.
sparg93
Expedition Tahoe
NJ
Just used it as an example b/c I can't figure out why LESS pressure on the pad would result in stopping faster...unless the individual used two different pad materials.
Keeping everything else the same, I think the x2 54mm pistons would reduce the pressure on the brake pad more then x1 80mm piston.
My thoughts - the pedal is essentially the "lever" for the master cylinder, or the "pump".
As an example, if you push the lever 3", the pump is going to push "x" amount of hydraulic fluid to the caliper. Whether there is one or multiple pistons, they are still voids in which the hydraulic fluid is going to go (the "voids" are the distance between the back of the piston and caliper housing).
If you take an extreme example of x6 54m pistons (300+ total mm), you are going to need a ton of hydraulic fluid to actuate all those pistons. As the pistons are moving forward to clamp on the rotor, fluid is filling the void...the large the void, the more fluid needed.
I'm assuming the PSI rating was established by putting some form of sensor between the brake pad and the rotor...therefore the pad doesn't know there are x2 pistons, just 108mm of a void that was filled with hydraulic fluid.
I'm not sure if that is the best way to view it b/c i'm not a fluids guy...but that's my thoughts :)
I only meant replacing 1/2t calipers with 3/4t calipers was a waste of money w/o hydroboosting the brakes. If someone is NOT going to hydro, I would serioulsy recommend replacing 1/2t calipers with 1/2t calipers...by going to the larger 3/4t calipers, you may increase your stopping distance over the 1/2t calipers you originally were using.
Not yet, but I will try it this weekend!! The more I thought about it, I don't think pulling the fuse is going to be the fix for me. When I smash on the brakes, the ABS isn't even kicking in until the very end of the stop... it's literally like the calipers are not exerting enough pressure on the rotors to slow them down to the point the ABS kicks in.
steamroller
The South
My guess is the larger piston is applying (even if it's less) pressure over a larger area of the brake pad backing plate. Too many variables and everyones vehicles are set up different, plus what may be good braking for one person may be terrible for another. Try driving an old car or truck with manual brakes and drums on all 4 corners...it will make you appreciate what you've got :)
Haha I'm far from an expert, but at least there is some tech being posted without no one getting hurt feelings lol. That was what I was getting at-the stockers are 75mm and the 3/4 tons are 80mm. So 5mm or 7/32" or so. I would think the pressure loss would be minimal but you gain a somewhat larger apply area over the pad. Everything I could find when looking at this a couple years ago shows the Limiteds and the police package SUV's use the same master cylinder even though the calipers are larger.
In the article they switched to SSBC's overpriced master cylinder and they said there was no pressure or volume difference, even though the piston in there was larger. It just actuated the brakes faster. From what I've been able to find out it's a NBS master with an adapter fitting and looks like they used a pressure gauge screwed into the bleeder port for the testing.
Hell at least try it out. IIRC it's the only 60 amp fuse in the underhood box. It's too bad no more info was posted in another thread about using the steering knuckles from a NBS so we could adapt the big dual piston calipers...I've even got a new set of the calipers that could be used for mockup.
:beer:
Monstar_est87
Monstar_est87
City of Angeles
O shit... Damn u guys have been busy... But yea im wit every1 on the hydroboost... I shoulda listened 2 atomic... He posted part #s on page 2 4 every1... And sparg, I cant wait 2 see ur write-up on the hydroboost setup... Ill b sure 2 reference it wen im doing mine...
sparg93
Expedition Tahoe
NJ
I can only imagine...i was pretty close to buying a '69 Camaro with a 454 yrs ago...my dad joked about how I planned to slow the damn thing down!
I found a parts catalog through AC Delco that had a hydroboost system for a '99 Police Package 5.7L and as you mentioned above, the 3/4t calipers....it made me believe that it (hydro) was at the very least an option on the police package for that yr...any ideas?
Hmm...if there is no pressure difference with the SSBC's master cyclinder, then the vacuum system seems to be the most important part of the equation. When you switch from vacuum to hydro, it instantly generates more pressure. My head is turning with ideas, do you mind sending me the link to the article?
Absolutely - I like using my hoe to confirm/deny ideas so hopefully one day I can put together an article that has some real numbers to back it up!
My wallet can not handle anymore ideas...but damnit, now you have me thinking! I can honestly say, if this hydraboost system significantly drops my braking distance, I'm moving on to some other component of the truck's hardware to mess with!!
After I finish the hydro setup I promise to post all of the stopping distances.
As a side note: I even put the tires/rims back on from when i first tested my stock 1/2t calipers...to keep everything constant. The second I'm done with installing the hydra setup and testing, the new rims and tires are coming on!! (this yr i switched to winter tires with all the snow in the area for a few months)
steamroller
The South
Quoted it for you. Another thing they did was completely eliminate the ABS all together, but didn't recomend it for liability purposes I assume. I could see where it useful in certain weather conditions but like the article says I believe it has alot to do with the pedal feel they have........Dad's C10 has the same size calipers on his 85 C10 and the brakes work pretty good on it, almost seem too touchy the few times I've driven it. It's much lighter than mine too though so that could play a factor in it. :shrug:
I did some cross referencing when looking at this stuff using VIN's from Ebay and punching them in on Compnine's website.
http://www.compnine.com/vid.php
There Tahoes/Yukons stop at 1996 I think if you're looking for exploded diagrams and part #'s....The OBS Escalade/Denalis are listed under the 2000 model year IIRC. As far as I know there were only 3 size master cylinders used 1 1/8" for JB5, 1 1/4" for JB6 and the Hydroboost master-don't remember the size on it.
Keep us updated on the swap, I've put off any other brake upgrades until I find a front axle for the SAS......Otherwise I would be looking harder at trying to make the NBS knuckles/rotors/brakes work on mine along with adding Hydroboost
:Handshake:
sparg93
Expedition Tahoe
NJ
Atomic - you posted part numbers for the hydro setup.
I've found two hoses (power steering to hydro) that are required, but I can't tell if I need any extra brackets, fittings, etc (other then the plate on the firewall).
If you look at Whipple's setup, he purchased a $200 hose kit from hydratech and it came with a bunch of fittings and other parts...any idea what they are for??
AtomicHoe094
Atomichoe094
cleveland, OH
those fittings are just for the hoses that hydratech made. You can make your own lines instead of buying new ones..
check out Anplumbing.com
Theyll have everything for you..
Brackets, im sure you dont need anything.
Those 2 silver things in the package with the circles. look like they are just hose clampers. Kinda like spark plug wire separator things.. You know what i mean.. Just to make it more "clean" install and not having zip ties or something..
sparg93
Expedition Tahoe
NJ
ok, that's what I was thinking.
AC Delco on those two hoses are like $30/ea...i can't figure out why that setup (Hydratech) is $200 for two hoses and some fittings that I can't see the benefit of!!
General Fodder
