00-10 5.5 Inch Drop Spring Tahoe/Yukon Rear
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
I installed these coils on my 07 Avalanche over the weekend and I can tell you these thing ride like a caddy!!!
I have the DJM Rear Hardware kit and DJM shocks and it rides great. Couldn't ask for more
I will get measurements tonight and I will try to upload some pics soon.
Thanks to Tony for all the help!!
Josh
so josh how are they holding up for yah :)
Max
Mile High
Denver
I didn't know the helper bags fit inside these, I may have to scoop a set from you now.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i said that a few times allready guys where have you been at lol
1lowhoe04
Fort Worth Texas
does DJM make a 6/7/8/9 inch drop lol causr ide like to get one ive cut the shit out of this DJM 5inch spring like totally in half and wanting to ditch it ! LMK i dont want to raise it i still want to be the lowest tahoe in my city lol
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
on the guys that want to cut i use the belltech tb spring and cut a coil off then smooth the edges that will drop it 6.5 inches over stock then i use the airlift bags inside. You will need to run a shock that is 18 inches extended. Using the same set up on my wifes truck now and have done prob 50 local trucks like this over the past years with no problems. I was tryign to get a spring made to set us this low but not enough people were interested.
http://www.tbssowners.com/forums/showthread.php?t=56608
the djm tb spring when cut loses a lot of its quality due to design and 99 percent of the people like the way it rides and sits low enough. But for customers that want to get lower I install the belltech set up and cut a loop along with the rear djm hardware kit and shocks with airlift bags and its fine.
on 305 35 24 and this spring the back sat at 31.5 with no air in the airbags.
Max
Mile High
Denver
Damn I hate cutting coils but that may solve my issue with these belltech tb coils, little bastards just need a little more springrate.
1lowhoe04
Fort Worth Texas
ill go and take some pictures of what mine sits at ow but i got that 5 inch spring cut almost in half and sits nice and i am running tahoe 20s 245/50/20 pictures will be up tomorrow
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
the main thing the coils ONLY CUT OFF THE TOP do not cut the lower side. You need the placement on the rear axle. ive never had issues with the tb coils cut as long as you use that airbag i put in the post. because when the truck sits down its only like 5 inches from top to bottom of spring clearance. ive done tons of the tb coils cut off the top and flat cut the top spring and no issues.
1lowhoe what does your truck sit at now from ground to fenderlip?? if you have 245 50 20 it should sit at like 29
---------- Post added at 12:00 AM ---------- Previous post was Yesterday at 11:58 PM ----------
with the 5100 series bilstein ride honestly is not as good as with the djm 1800s with the cut tb spring and airhelper bags.
Max
Mile High
Denver
Did you use the standard 60769 airlift bags? The issue I have with these is they collapse onto themselves due to the low springrate, bags could solbe all that but I like being 31" at all corners. I'd like to just swap everything out for king or fox coilovers and put some struts up front. Sigh.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i never use those i use the 60748 kit. its only 5.5 inches tall.
with your 20s and the tb coils cut off the top only like i posted in my link you should be 31 easy at all corners and ride great.
Max
Mile High
Denver
You think rancho 9000XLs would ride better than 5100s?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
honestly the djm rear shocks just like everyone else here has been doing ride really good.
first of all id start with the tb coil cut like i show in that pic and use the air kit I listed
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
how much are your rear belltech tb coils cut now? what shocks and bags are you running?
Max
Mile High
Denver
They aren't cut at all, I have the 60769 bags but haven't used them since I swapped out the 5305 coils (which rode much nicer). Rear shocks are 22.5" Bilstein 5100s with belltech 6651 shock extensions, ride is decent for how low it sits but I know more can be had and bags would be nice for towing.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
put the tb springs off the batt see where it sits then go from there. They ride good.
Drift Union
cant pm due to posts.
What is the most static drop you can get away with without frame notching with, air helper bags? (2002 escalade)
also why dont I see more people with 3in arms and drop spindles? am i missing something, wouldnt that be and easy way to drop the front tons without messing with the spring rate of the torsion bar?
Im in between a rock and a hard place. Im addicted to slammed vehicles, but bough my escalade to tow my car around in the summer......
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
not many people want to go 5 inches in front but ive done a lot of them
for the front you can do the djm 3 inch a arms with djm shocks and belltech 2 inch drop spindles for 5 inches. In rear you can do the djm hardware kit with the djm 1800 shock and the tb spring cut 1.5 loops and use the air helper bags from airlift and you will be pretty good.
but what size tires are you running on your truck.
rear tb spring cut with helper bags
X-ray Nerd
