installing a leveling kit
pm80
Anyone who has installed a leveling kit. How hard is it. Any special tools needed any tricks that worked well? I have mine in my garage and am going to try to install next week. Just wanted a heads up on any problems I might have.
thommybee
Dtown
Nahh its easy......its much better if you have another person to help you out tho.
P
pm80
Thanks for the vote of confidence. I can turn a wrench, just never messed with the suspension.
2 E L O
Omaha, NE
It's pretty straight forward....but like mentioned previously, it's much easier if you have someone handy to help out.
Just ordered the ccm kit today! Those of you who have installed already, are there any special tools that are needed besides the metric stuff....floor jacks..etc?
White07Tahoe
New Orleans, LA
Def need 2 people. Sawzall to cut the strut bolt tips, or you could use a hacksaw but it would take a while. I didnt do the rear myself but the guy who did it for me said it was kind of a pain. I couldnt get the rear high enough to get the spring out, might want to try a spring compressor but Im not sure if that helps.
If you didn't have the hacksaw would it be a problem? Or is there a way around it that you know of...
White07Tahoe
New Orleans, LA
No you have to cut the top of the strut studs for the 2 1/2" spacer to fit over the top of the strut. The strut studs are about 3" tall which means the 2 1/2" will now fit. You can buy a hacksaw cheap at any hardware store, I also used a lubricant so it did not heat up and damage the blade but you dant have to.
emann_01
I am also getting ready to put in my leveling kit but i haven't heard/read of cutting anything.
P
pm80
I found a good write-up on an install of the ccm kit I will post the link later. It is on my other computer.
I am going to be doing mine next mon so after that I could probably give you some better feed back.
---------- Post added at 08:13 AM ---------- Previous post was at 08:12 AM ----------
You don't have to have a sawzall either u can use a cut off wheel too or a hacksaw. IT is just slower with the hacksaw.
2 E L O
Omaha, NE
I just used a cutoff wheel air tool....it made quick work of the strut studs so I was able to get the CCM spacer on. The CCM kit in itself does not void your warranty. If you have a bad strut for some reason, the dealership probably wouldn't replace that under warranty even without a leveling kit. If you have a bunch of miles on your original struts it would definitely be wise to replace them while you're installing the leveling kit.
Okay guys, thanks for the advice.
---------- Post added at 10:15 AM ---------- Previous post was at 09:55 AM ----------
Found this thread....
http://www.gmfullsize.com/forum/showthread.php?t=181163#post3669064
Didn't know if it was the same one..but it is pretty good/helpful.
emann_01
is the ccm leveling kit front spacer one solid piece?
jeffbrown65
Tipton, OKlahoma
I installed the ccm kit on my yukon about a month ago. i jacked up the rear of the vehicle and sat it on jack stands at their highest setting. Then i removed the wheels/tires and disconnected the rubber hoses from the bracket on top of the pumpkin. That allowed me enough travel to install the spacer under the coil springs.
CrackerJack135
