Complete Lighting/LED List
shakin
Atl ga
All the white is 5k and me dash is 6k
Sent from my HTC Vision using Tapatalk
strykerG8
put LEDs behind the dashboard and in the doors today. bought them on ebay. 10 LEDs for 2 bucks shipped from hong kong. dash looks alright, doors look better. still waiting on my other shipments though.
Dr. Overkill
El Cajon, CA
Lotsa hotspots there. I've been reading some other threads on fullsizechevy and think I'm going to go with superbrightleds HP5 model. It's the high power surface mount type LEDs and has a forward facing LED as well as 4 radial ones to shine outwards. Pix with those show very uniform lighting.
strykerG8
yeah these are all forward facing. they work great in the doors. i'll see if i can find a deal on some SMDs.
rdhenderson
Bellingham, WA
So I have replaced 95% of the interior lights to LEDs. However, I have something strange happening. When I went to replace the lights for the instrument panel indicators the 2 bulbs for the ABS and the Airbag appeared to be a bit different from the others. They had a twist lock base but the bulbs were not removeable. So I purchased 2 new twist lock bases and put some LEDs in there. Now the ABS and Airbag indicator lights constantly stay lit. Any thoughts?
Dr. Overkill
El Cajon, CA
That's strange. I have no idea but something you might try is swapping one of your new light/twistlock combos with one of the OEMs you still have in there, and see if the problem switches places. At least you'd know whether something is screwy with the light/base combo or if perhaps something happened to the board during installation (seems unlikely though).
I'll be interested to hear others' opinions on it :hmm:
strykerG8
anyone have any idea to get rid of the hyperflash on the turn signals? am i going to need resistors on all the flashing corners?
strykerG8
don't know which flasher to buy for our trucks.
anyway, i replaced the dashboard LEDs with the hong kong version of the superbright LEDs HP5 model. 6 bucks shipped for 6 LEDs.
Dr. Overkill
El Cajon, CA
$1 each? *kicks self*
I'm curious why your trip meter and odo are still white. Mine glow blue from the gauge lamps.
HotCarl
ID/WA
How do you remove the actual map lights from the assembly once it is off the headliner? the bulb is inside the housing and I cannot figure out how to get to the bulb?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
push up and rotate lamp housing. it should drop down. Like take on a bulb on you parking lights. Once out you will see the socket being held to the housing with two snap clips.
98chubby
Has anyone replaced their blinker, well both of them i believe they are part number (211)? Anyways my question is do they come with the dual lighting from superbrightlights.com? I'm looking at the pic and it doesn't show the back to them any input would be great. thanks
SunlitComet
OBS Jedi-Do Good
211 or 211-2 is a festoon bulb usually used in the dome lighting. Are you perhaps talking about the flasher unit. For what year? Also the url you type is a parked ad page. What are you trying to do exactly?
98chubby
I want to replace the lights that are below the headlights, which I believe are the blinkers. Help..
TejasPitt
