3/5 DJM with 24's
Nelson
Here are some pics of the 3/5 drop from Tony with TB coils.
305/35/24. Pulled the Air bags out and went this route. The ride is great. Front is 31.75" and rear is 32.75". If your on the fence thinking about this kit I would recommend it. Tony was great to deal with everything shipped fast and arrived when he said.
N
Nelson
No it was bagged before. Air bags are great just not if you live somewhere that it snows. Got tired of my valves freezing.
felixgun
Lafayette, LA
Looks PERFECT! So clean...
:drool: That is one sexy set up!!!
Hold on a sec.... :drool: ....
Ok, I think I'm done now! I like it! :waytogo:
NORCAL SS
SUV SUSPENSION GURU
right on another happy customer. I know a lot of people are on the fence about the tb springs but hands down the djm tb springs with the rear djm shocks/hardware kit is the best riding 4 inch plus kit out there and also sits the lowest.
hell the tb springs ride even better than the 3 inch ones ive installed.
btw here is the kit he ordered from me
http://www.tbssowners.com/store/index.php?act=viewProd&productId=88
Nelson....did you do this install yourself? If so, how difficult and how long did it take you?
N
Nelson
Yeah I installed it myself. They are easy took about 2 1/2 hours. I had to fab new lower coil mounts since my where cut off when it was bagged and I my rear bump stop brackets where already off. I was a suspension installer for 15 years so I have these down. If it was your first time and just using hand tools it would be all day job but nothing that you can't do in your driveway or garage.
:waytogo: I've talked with tony about just rear springs for a 2" rear drop but the more I see you all with your 2/4 and 3/5 drops I'm starting to rethink especially if it's something that can be done in the driveway. I'm a do-it-yourselfer so try to do all I can on my own
Good info to have! Thanks!
N
Nelson
I would go for the 3/5 glad I did. Installed a ton of the 2/3 mostly on soccer mom rides they look good but not a whole lot of difference from stock.
NORCAL SS
SUV SUSPENSION GURU
on the burbans id do the front djm 3 inch a arms very easy to install and the rear kit with the tb springs. its faster to do the newer 07 then the 00-06 trucks using a arms.
98crewcab
Sacramento, CA
hate to send you out with a tape measure, but what diameter is your tire? my wife only has 22's, but alot more tire. and wants a 3/5. want to be sure of the clearance....thanks in advance:)
NORCAL SS
SUV SUSPENSION GURU
with the 3/5.5 drop on my customers trucks here are the tire sizes you can have as long as your offset is right.
285 40 22
285 45 22
305 40 22
here is a djm 3/5.5 kit that I did and 305 40 22
carcrz
Georgia
love the truck good job, nelson what did you do with the air bags and what name brand were they.
With that 3/5 can you still run the stock rims and tires for the winter months? I've got a feeling that the answer is a "no" on that but thought I'd ask. We get snow where I'm at and stock rims and tires makes it quite a bit easier to get around in it! :)
NORCAL SS
SUV SUSPENSION GURU
answer is yes done it many times.
dizhai
