cam position sensor
mikeykey
It's either under the distributor cap and rotor or near the front of the block on the bottom side.
cam shaft sensor and the crank shaft sensor always messes me up on the location. hope this helps...... I had to replace both of mine.
Whippled2dr
Stock
SF Bay Area
Cam position sensor is located in the distributor. The one on the timing cover is the crank position sensor.
mikeykey
of course thats all the way in the back how hard is it to change and how far down?
If your ref. to the cam sensor, just remove the dist cap and rotor, two screws and it comes right off.
If your ref. to the crank sensor, slide under your truck and in the front bottom side of your block, its held on by two screws.
Both very simple
hapyspaz
Austin
Cam Sensor
briannorris
