Help with new stereo installation
GmcYukon99
I used a universal gm car stereo wire harness to install my sony CDX-GT250MP into my 1999 yukon denali. When i tried to play music from the radio, there was no sound or static. I then used my ipod and a Cd but nothing happened. No sound coming from any of my speakers. I also took back out the sony radio and put the stock radio back in and the speakers worked fine.
Any help would be great thanks
denali02
also you may have to tap your amp wire into the remote because thats what i had to do had the same problem
SunlitComet
OBS Jedi-Do Good
unknown at this time.
There should be a pink wire in the wiring harness that led to the oem radio when voltage is supplied to it Itshould activate the amp relay. However it should not effect all the speakers unless you have luxury option in which case it will.
Diller
Cedarburg, WI
He does have the Luxury Option, as he has a Denali.
Diller
'99 Yukon
'08 Hummer H3
G
GmcYukon99
ok a few more questions. wheres the amp and whats the quickest way to get to it?
D3NALI_99
same problem
i have the same problem for same exact year and model...!!! no sound coming out of speakers ... hooked up with universal harness and its also a 1999 denali
raptorforme93
Tampa, Fl
Is it true that if the romote wire is hooked up to the HU but not the amp and the other end of the remote wire gets grounded that it could short the HU and it will no longer turn on the amp when powered up?? I have heard that before.
briannorris
